240sx Help
Old Feb 21, 2008 | 06:24 PM
slicedbreadno2's Avatar
240sx Help
Alright guys, I got my 240sx. Unfortunately everything in the engine bay was disconnected, there was no radiator and or battery. I precede to purchase the battery and hook everything up and all of the lights turn on. I try and crank the car over and it's a no go, the second attempt I try it and a small flame shoots out from the front of the passenger side, I step out and look on the ground and it is now covered with oil. Is my engine now completely dead? and should I be looking for an SR20? or can I still fix this engine for a fraction of the cost, and just swap another engine later on when the engine completely dies?
Old Feb 21, 2008 | 06:26 PM
pwrofturbo's Avatar
Sounds like you bought a car with a hole in the block.
Old Feb 21, 2008 | 06:41 PM
lookEVO's Avatar
Club240.com
Old Feb 22, 2008 | 02:35 AM
PurgeIt's Avatar
You should be able to get a KA24DE for about $500.00... but I wouldn't run that thing for long, considering the mileage 240s have in em. I think your better bet would be do a swap. As long as you're gonna spend money on the engine, why not upgrade?
Old Feb 22, 2008 | 05:54 AM
SuperHatch's Avatar
Not all swaps are upgrades.
I'd stick with the KA... plenty of potential, and plenty cheap to find replacements.
Old Feb 22, 2008 | 06:30 AM
battosaii's Avatar
500 bucks?!?!? wow if u buy one for that much u might as well grab your ankels
i got 2 perfectly running KA24de for $200 for Both
Old Feb 22, 2008 | 09:49 AM
subaruwrx420's Avatar
Well, check to see if you in fact have a H.I.B = Hole-in-block. If not, then check for fuel and spark and go from there.
If you have any local junkyards, check those for KA motors...there are plenty around where I live. I got a complete engine, including wiring harness, and all accessories for $200.
I'm currently running a Garrett 57 trim turbo on that stock engine that has 100k and it's loads of fun. KAs are plentiful and cheap as was mentioned. SRs are fairly easy to obtain but much more expensive, they can also blow up and the cost of replacement is much more as well.
Good luck.
Old Feb 22, 2008 | 06:51 PM
chrisbiltoc's Avatar
Originally Posted by lookEVO
Club240.com
+1
tschad
18
Mar 5, 2014 08:38 AM
Nismo2evoawd
Dec 8, 2012 02:16 PM
Street240sx
50
May 15, 2012 01:49 AM
Thebigjoke1337
18
Aug 1, 2010 04:36 PM
HighwayStarX
10
Jan 23, 2009 08:48 AM
