My 1999 Evo powered Galant
Old Dec 20, 2008 | 08:03 PM
VTEC Killer's Avatar
Well it was EVO powered, I had a JDM EVO VII motor in it, but now I switched it up bit.
Here she is in all her glory, she is a little dirty, but I wasnt about to wash her, its 34 degrees outside... Im putting her to bed for winter.
I still have to lower her some more up front and install my brembo calipers/rotors, but thats gotta wait til it gets warm again.
That exhaust is killing me, I was going to just redo it now so its aligned in the bumper cutout, but I wanna get a new muffler, so its gotta wait.
Engine bay, still dirty as hell from being in the dusty *** body shop
color matched the strut bar
The shifter bezel, radio bezel and door switch bezels are painted EVO MR Gray, new carpet, new seats, door panels and headliner wrapped in black suede.
No dyno numbers yet, but I should be around 450whp on pump gas and 550+whp on race gas.
Here is what I have done to it, im sure im leaving some stuff out
4G64 Block w/EVO VIII headswap
Eagle/Wiseco
SuperTech +1mm valves
Crower springs and retainers
HKS 272 Cams
Hafe SS DSM manifold
Precision SC6152E turbo
2.5 - 3" transition dp then 3" exhaust and magnaflow muffler
twin walbro 255's with -8AN lines
AMS Fuel Rail & RC Engineering 1000cc injectors
Spearco FMIC
2.5" hotside piping, 3" coldside pipiing
Tial BOV and wastegate
Koyo JDM EVO5 radiator
B&M Oil Cooler with -8AN lines
Innovate Wideband, Prosport Gauges
AEM EMS
Tranny is from a 2001 Eclipse
Swapped the car to 5 speed
trans rebuilt by Gary @ the grave
Quaife LSD
Megan racing short shifter
Fidanza Flywheel
ACT 2600 w/ 6 puck disc
Kartboy brass shifter cable bushings
Energy Suspenion shifter base bushings
Megan Racing 32 way adjustable Coilovers
RMDSM Front and Rear Swaybars
PowerGrid Engineering adjustable swaybar links
Prothane/Energy Suspension motor mounts
swapped rear drums to disc from a 97 GST
not installed yet Brembo 4 piston front calipers, 2 piston rear calipers
and Gruppe-S SS brake lines
Exterior
Full JDM coversion with OEM JDM parts, no fiberglass replica's
headlights, fogs, tails, front and rear bumpers and sideskirts
Konig Runaway 18x8 +35 offset
Kumho SPT 235/40/18
interior
refinished dash, trim and door panels on black
suede wrapped door panels and headliner
custom made shifter bezel and gauge bezels/pods
new black carpet
Sparco Chrono Road seats
not installed yet Sparco Harness' and JDM steering wheel
Old Dec 20, 2008 | 08:06 PM
rush63's Avatar
Sleeper!!!
How's the torque steer?
EDIT: I see you got LSD.
Old Dec 20, 2008 | 08:13 PM
VenomEVO8's Avatar
That is one Clean install..
Old Dec 20, 2008 | 08:16 PM
Mitsutech56's Avatar
That is awesome. I was thinking of an outlander awd with evo powertrain as my next project.
Old Dec 20, 2008 | 08:32 PM
Originally Posted by rush63
Sleeper!!!
lol
even with the LSD its still pretty rough at WOT in 1st and 2nd gear. it is almost gone midway thru 3rd and then 4th is smooth sailing
I havent had any major tuning done, right now im guessing at 15psi its making about 325-350whp or so. I did a highway run in 4th and I got it up to 140+ MPH, I really gotta get the car corner balanced and have a good wheel alignment done so it stays stable going that fast. Im hoping to get a mid 11 second or better 1/4 mile pass out of her.
Old Dec 22, 2008 | 01:34 PM
Chris@nolimitmotors's Avatar
10 years in the making lol. Looks good Brian.
Old Dec 22, 2008 | 03:09 PM
LOL
Only 4 years in the making.
It woulda been faster if I didnt have to buy/build/blow 3 motors in this car thanks to the shoddy work of that shop. Ever since I started working on the car myself, stuff seems to work.
Old Dec 22, 2008 | 03:15 PM
purevibez's Avatar
nice convert man, looks real clean and meticulous
Old Dec 22, 2008 | 11:53 PM
Wayne99gsr's Avatar
Nice!! So since you said you got a eclipse tranny so its FWD?
Old Dec 22, 2008 | 11:56 PM
ChrisBond1's Avatar
this is real nice. definitely get tune and dyno'ed. i wanna see some good results from this. :]
Old Dec 23, 2008 | 12:25 PM
yeah its wrong wheel drive
At the track I should be OK tho running a full slick. The car has alot of top end in it still even with the redline at 7500. From 3500-7500 its an animal.
Old Dec 23, 2008 | 12:28 PM
prodigalsunn's Avatar
i don't have any pictures but stock enkies look great on galants and diamantes. i put my stockers on my 97 diamante and fitment is perfect. perfectly flush with wheel wells front and back
Old Dec 23, 2008 | 01:39 PM
dc_style's Avatar
how's it drive? differences between evo and galant?
Old Dec 23, 2008 | 04:24 PM
its got more top end because of the fwd. Like an evo is a rocket out of the hole but then kinda evens out up top, mine is like a slug out of the hole spinning tires but 3rd and 4th gear are insane. I have had 4th up to 140+MPH and it pulls hard all the way to redline in every gear. I might change the turbo and intake manifold over the winter, but im not sure yet, I still kinda wanna see what it makes as is. When I had the EVO VII motor in there, I had a built bottom end 9:1 with a stock head, stock cams, stock manifold, smaller piping and smaller fmic and I made 370whp on 16psi on 93 with very conservative timing. This motor just loves boost. The 2.4 is a nice motor on the street, out of boost its still peppy so you dont really feel any lag.
Old Dec 23, 2008 | 04:26 PM
Billy@EnglishRacing's Avatar
very nice
