Somebody Help. I'd Rather Not Die lexus gs300 problems
Old Jan 30, 2010 | 10:46 AM
GearDownSon's Avatar
Originally Posted by lookEVO
I second the warped rotors and bad engine mount.
Have someone watch the engine while you sit in the car, put it in reverse and drive while braking and giving it gas. Switch back and forth a few times. If the engine seems to rock WAY more than it should, you have just diagnosed said concern.
I agree.
Check your lugs as well.
Old Jan 30, 2010 | 11:39 AM
bcollinstex's Avatar
Originally Posted by CaliMR
because by that point it is all hot and squishy
smexy talk
Old Jan 30, 2010 | 01:29 PM
Kryptonite's Avatar
Check your EGR valve clearance, possibly the valve is violently shaking to the point of exploding. Those things are dangerous by nature.
Old Jan 30, 2010 | 02:19 PM
hotrod2448's Avatar
Gas pedal recall possibly floor mat malfunction.
Have you looked at the wheel bearings? Are the tires just worn out or are they wearing in a weird way?
Old Jan 30, 2010 | 03:03 PM
sblvro's Avatar
moved to other cars. thanks OT
Old Jan 30, 2010 | 09:44 PM
shvc1991's Avatar
Took the fall and spent whatever money I had and replaced almost everything besides the brakes rotors, brake pads, and brake fluid. Only getting pulsation from the brake pedal now. Steering wheel shake is nearly gone, but I am positive it's just a tire that's out of balance as it comes at 60 mph and goes at around 75 mph.
I replaced the LBJs, control arms, steering bushing, power steering fluid, tie rods, and I have tires on the way. My current tires are illegal as they have virtually no tread left. Once those tires are mounted I'll be getting a balance and alignment. And I also tightened the steering pre-tensioner. Got all of this done yesterday in my driveway and it was ****ing cold.
It was not a motor mount issue btw. I was really hoping it wasn't too
Old Jan 30, 2010 | 09:46 PM
sblvro's Avatar
better get those tires now! the winter triple whammy is heading your way=snow,sleet,ice. we just ours.
Old Feb 15, 2015 | 04:40 PM
pOOshy's Avatar
yeah sounds like multiple symptoms. wheels, rotors, steering rack?
Old Feb 16, 2015 | 05:16 AM
blk4est's Avatar
My wifes Lexus has a issue with the transmission that has us not wanting to keep it. They have problems unlike what the lexus people want you to believe.
skyseer
17
Jun 29, 2025 10:02 AM
akride907
Mar 17, 2016 02:13 PM
KingTowel
13
Nov 5, 2015 02:25 PM
Sev
17
May 15, 2015 01:01 PM
anjapower
50
Feb 15, 2015 04:39 PM
