Project 2G 8's and Street Driven
Old Sep 11, 2011 | 08:07 PM
TALONGT's Avatar
Project Auto 2G DSM 8's and Street Driven
New project this year is to convert my 5 speed 1997 Talon AWD to an Auto, and go after that 8 second mark while keeping the car streetable. The car has gone 9.6@159Mph with the 5 speed, at 3250lbs. And when it comes to auto's the natural choice is the crew at English Racing, thanks to Lucas, Jeff, Arron, and Myles. I hope I can tuck into the draft behind you guys I will still be running a full sequential Spark Tech ignition system, but pretty much everything else on the car is going to be changed, and I mean everything! Going to be running Comp triple as usual on the car as it has all been an outstanding performer both in power and spool but also in durability. More to come
Video of the car going 9.6@157, and on the dyno
http://www.youtube.com/watch?v=eNEqyEsN-P4
Old Sep 12, 2011 | 02:12 PM
SparkTech's Avatar
Congrats Ron. Good move the Autos have proven themselves in a relatively short time. Of course you also have a winning combo of vendors on your side also.
I'd suggest adding the Billet coil protectors to prevent coil breakage.
Attached Thumbnails Project 2G 8's and Street Driven-stbrokencoil.jpg   Project 2G 8's and Street Driven-purple_billet_caps_0053.jpg   Project 2G 8's and Street Driven-purple_billet_caps_0058.jpg
Old Sep 12, 2011 | 02:41 PM
TALONGT's Avatar
Exactly I was going to go RWD untill Jeff and the English crew got that auto awd so dialed in I couldn't resist myself This project is going to be tons of fabrication, but I think the end results are going to be something that no one else has done before Stay tuned everybody
Old Sep 16, 2011 | 07:38 AM
TALONGT's Avatar
Sorry that was an old video here is the video of the 9.6@157Mph pass
9.6@157Mph
Old Sep 17, 2011 | 07:20 AM
JorgeYaHeard's Avatar
That is a clean car, looks like it doesn't run bad either. Good luck on getting to the 8's.
Old Sep 28, 2011 | 03:18 PM
TALONGT's Avatar
Whats left of my old 300M upgraded 5 speed transfer case
And the new auto transfer case after machining for the larger 300M output shaft and re- setting clearances.
Old Sep 30, 2011 | 06:28 AM
TALONGT's Avatar
New 6 bolt to 2G Auto adapter plate
Old Oct 2, 2011 | 12:30 PM
TALONGT's Avatar
So besides an all new engine, trans setup, I'm also redoing the whole chassis. Out with the 8.5 NHRA certified cage and in with the new 25.4 certified chassis. This is going to be alot of fabrication cause I'm going to do it in the car using what I can from the exsisting cage.
Old Oct 6, 2011 | 07:37 AM
TALONGT's Avatar
More parts for the auto swap my Kiggly 6 bolt SFI flex plate, ready to bolt up
Old Oct 10, 2011 | 10:40 AM
TALONGT's Avatar
New Kiggly HLA to help limit the amount of oil getting pushed up to the head a common problem with these motors if turned at very high RPM.
Old Oct 14, 2011 | 09:30 PM
TALONGT's Avatar
So just recieved my new set of Wiesco HD Pistons for my 2.0L build, going to clean them up and do a few tricks and then there ready to install
Old Oct 16, 2011 | 12:31 PM
6thGenJed's Avatar
dope.
Old Oct 19, 2011 | 11:50 AM
TALONGT's Avatar
Most of the parts are at the machine shop for the short block and going to start the chassis part of the build on next days off
Old Oct 22, 2011 | 11:38 AM
TALONGT's Avatar
New rods awaiting some final machining and still need to build a jig for the bearings This is going to be a light weight setup as I plan to turn this motor alot higher then I have my 2.3 in the past.
Old Oct 22, 2011 | 01:25 PM
gwiffer's Avatar
Nice rig!
