Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
Clutch
Old Aug 10, 2007 | 04:15 PM
06EVOIX SE's Avatar
Clutch Install Help!!!
I'm doing my clutch my self with some of my friends. Is there anyone who has done it welling to stop by and help or offer some in put. I will probably be doing it before the end of the month no exact date yet.
Old Aug 10, 2007 | 05:52 PM
YellowEvilEvo's Avatar
might be doing mine the weekend of the 24th, if not next weekend. I'll let you know what I run into. Also we'll wait and see how it goes for Dennis. I am going to swing by the HS during the week and give him a hand.
Old Aug 10, 2007 | 08:27 PM
dee_yamaha's Avatar
I'm starting this Wednesday at 1 pm, hope to get everything removed by the first day, I have two days to do it (3 day pass)..too bad they don't open on Tues but its all good cause I need to install an alarm too. The worst part is probably droping the tranny and then putting it back on. I hope they have a tranny stand/lift like they did in Guam.......
Old Aug 10, 2007 | 10:04 PM
06EVOIX SE's Avatar
you are doing it on ft meade
Old Aug 11, 2007 | 05:17 AM
We are both doing the clutches at the fort. Dee they do have the Tranny jack/supports as well.
Old Aug 11, 2007 | 06:17 AM
05WhiteEVO8's Avatar
I will stop by and check you guys out as I live on the Fort.
Old Aug 11, 2007 | 09:08 AM
06EVOIX SE's Avatar
How much do they charge per day. and can you do weekends
Old Aug 11, 2007 | 09:20 AM
Tarmacisback69's Avatar
i do not recommend doin this if u havent done it before, a bad clutch install can result in thousands.
Old Aug 11, 2007 | 11:29 AM
06EVOIX SE's Avatar
i did it on my old car by myself in my garage on my back, had to take it in and out 5 times because of Clutch masters, it was on a 05 chevy cobalt ss supercharge. they never put the clutch in the car so me and a couple of other people ended up being test dumbies, because they never told anyone that. they had to buy me a new tranny, starter and flywheel
But i never did it on a AWD, but my friend did it on his STI, which i know isn't the same but i consider myself pretty macanilly inclined.
Old Aug 12, 2007 | 11:08 AM
dee_yamaha's Avatar
That is very true! Attention to detail is a must on this install.
Old Aug 12, 2007 | 09:45 PM
06EVOIX SE's Avatar
do you know how different the IX install is from the VIII, i was looking on evomoto at the install and is the ACD a problem.
Old Aug 14, 2007 | 06:09 PM
Any update on date and time?
Old Aug 14, 2007 | 06:16 PM
MIVEC8's Avatar
I agree. Save yourself the trouble and have a reputable shop do an install for you. There is a shop close by me that is offering an Exedy OEM w/ install for $500. Can't beat that deal.
Old Aug 15, 2007 | 03:38 PM
06EVOIX SE's Avatar
not yet, still trying to get the money up, i'm on disaibility since my motorcyclye accident, but it will be before the end of the month.
do me a favor, can you get me the number i will do it tomorrow.
Old Aug 17, 2007 | 04:55 PM
dee_yamaha's Avatar
I just did my install couple of days ago, it took me about 13 hours, but the first day I took my time getting everything out, I used a lift and some air tools. It was a pain in the butt trying to remove the tranny all by yourself... since the AHS close at 8:30 pm I decided to call it a day.....on the following day Yellowevilevo showed up along w/ Greg and we got the tranny off in 30 mins...the problem I had the following evening was that I didn't snap off the TB off the wedge collar. Make sure you take a flat head and rotate it so it snaps off and the fork pedal goes back to the original position. Clutch removal went quick along with the FW and TB.....the replacement went quick too with no problems.....we used a tranny jack to lift it back up but we had to tilt it a weird way to get the other end clear the suspension (black cross-member support) but other than getting the output shaft through the clutch assembly and aligning the dowel pins we slap it in there on the second try...everything lined up and in place.
I hardly recommend to remove the passenger half shafts out of the way and remove the drive shaft (center to the TC) off the TC, we didn't remove the TC off of the car but to the side resting on the cross member...it sounds like alot of work but it'll give you more room to maneuver the tranny when you re-install it back on.
Another thing I did was to remove the rear bracket engine mounts..it kept grabbing on to the power steering lines on the removal process..
In conclusion, if you have the money I suggest call ISP since they quote was the best deal of all the speed shops I have queried, but if you have some friends that are mechanically incline has done some type of tranny install before...its a long process but its possible... this is my first AWD clutch install along with Nory n Greg but we were able to manage and got my evo up and running again.
If you guys need the output shaft removal tool, I got one made and it works great...let me know if you guys want to borrow it (after Nory since he's doing his next week).
Another thing good to have is a third arm assembly that sits on top of your car to hold the engine since its going to be hanging on one engine mount. Unless your going to use jacks underneath but we had my car on a lift.
Thanks guys for your help.... I really appreciate it!
