Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
SRS light ON
Old May 17, 2010 | 03:46 AM
4G63 T's Avatar
SRS light ON
Inadvertently disconnected Sensor, How or where to go for RESET
I did try diconnecting Bat. to no avail.
Old May 17, 2010 | 05:50 AM
Bobster22388's Avatar
How long did you leave the battery disconnected?
Old May 17, 2010 | 06:25 AM
Turbo01s2k's Avatar
Some cars will not reset just by disconnecting the battery...some will. I tried to reset it on my car as well...no dice. Any shop with a scanner can clear it for you. I would just go in acting like you want new tires, or brakes done and the bring it up. That way they will clear it for free lol.
Old May 17, 2010 | 06:55 AM
4G63 T's Avatar
Disconnected bat. numerous times the longer was 15 minutes!
Old May 17, 2010 | 07:10 AM
I think you can actually reset the codes with the Tactrix now, although I'm not positive on that one. You can ask Charlie probably
Old May 17, 2010 | 07:46 AM
dreyfus14's Avatar
You should be able to go to your local parts store and have them reset it. Most all major parts stores will check your codes for free and delete them as well. Advance, Autozone, Discount, etc
Old May 17, 2010 | 03:32 PM
evo 8 ya's Avatar
Most SRS codes need to be read/clear with a MUT III. AKA the dealer
Old May 17, 2010 | 03:35 PM
JordanS4's Avatar
maybe you didn't plug it all the way back in? are you talking about the sensor under the seat? i've had mine out many times...never threw a code.
Old May 17, 2010 | 03:46 PM
4G63 T's Avatar
Sensor by the headlight that yellow plastic clip thingy.
I've read Mitsu dealer charge $80-100!
Old May 17, 2010 | 07:06 PM
Thrilla's Avatar
Veteran: Army
I accidentally did this before too. I just went to the dealer, and told them that "it just came on." They scanned it for me, and cleared/reset the code.
Old May 17, 2010 | 07:10 PM
Dube's Avatar
Go to Autozone or Advanced. A guy did it for me, well. He told me what to do because they'd be reliable for it and get sued if something happens.
Old May 17, 2010 | 07:19 PM
Silver06evo9mr's Avatar
go to dealer and say it just came one. wtf..?
Old May 18, 2010 | 04:32 PM
djikonatx's Avatar
how much did they charge you .they want to charge me like 90 bucks for this..he told me cause they need to run diag
Old May 18, 2010 | 05:37 PM
tommy if it wont go off, PM or call me. I have another possible cause / solution
Old May 18, 2010 | 06:19 PM
Lonnie@LMS's Avatar
Most regular computer scanners do not include srs. Some bodyshops might have the proper software since they do a lot of airbag deploy crash repairs. We do not have the srs ability. I know the dealer can do it but of course will charge at least 1hr at their labor rate to reset it for you. If you disconnect an srs connector when the key is off it usually won't log a code but if you turn the key to the on position while an srs connector is still unplugged, you are usually screwed into getting it reset for $$. Unhooking the battery will only reset your clock and radio presets. It would be nice if you could do it through tactrix.
