Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
Help evo x running rich
Old Oct 17, 2011 | 09:03 PM
rmpyryt's Avatar
Bought a used evo x and it is running hella rich when I get on it. Found out that it has 950 CC bosch injectors and a Walboro Fuel pump 255. Any suggestions car is not bogging down, but I have a lot of black smoke coming out the back when I get on it. My friend was following me in his new evo X and he told me he couldnt even see the back of my car due to all the smoke. Any suggestions on what I should do? Tune for the injector? or just try to get some OEM ones for now?
Old Oct 17, 2011 | 09:25 PM
Noob Sauce's Avatar
get the car tuned...
Old Oct 18, 2011 | 06:09 AM
EvoX2NR's Avatar
Did you ever get the car fixed?
Old Oct 19, 2011 | 04:25 AM
rmpyryt's Avatar
Got the clutch replaced and the car drives great. Just running rich, friend of mine says I blow out a lot of black smoke when I get on it. Dont know what my a/f ratio is but SES light comes on occassionally. Wished I knew it had an upgraded fuel system before I bought it.
Old Oct 19, 2011 | 05:26 AM
EvoX2NR's Avatar
you might also have a boost leak... I am sure he didn't do such a great job putting the car back together.
Old Oct 20, 2011 | 04:49 AM
rmpyryt's Avatar
You are probably right. You know a place that can do a boost leak check and a tuner to try to help me out with a tune. Should have just bought a new evo x.
Old Oct 20, 2011 | 05:46 AM
EvoX2NR's Avatar
I can help you with all of it... I am not sure when I will be home specifically, but I will be home by the 5th at the latest
Old Oct 20, 2011 | 06:02 AM
boostedtres's Avatar
where in VA are you? based on location i can help or steer you towards someone who can help.
agree with above. its prob a combo of the upgraded fuel system, injector scaling, not being tuned, and poss boost leak over compensating with fuel.
Old Oct 21, 2011 | 02:21 PM
rmpyryt's Avatar
Today took the heat shield off and found out and found a loose bolt on the downpipe and a missing bolt on the bottomside of the downpipe. Also have a no name BOV on the car. Thinking I should just order a stock OEM one to try to track down my issue with the car running rich.
Old Oct 22, 2011 | 11:47 AM
Atlantic Motorsports's Avatar
Agree on the stock BOV. We've had lots of issues with aftermarket BOV's on X's.
valin
Cobb AccessPORT
Nov 14, 2011 08:03 AM
valin
Oct 3, 2011 07:30 AM
BigT
18
May 1, 2011 12:35 AM
evodan_socal
Oct 24, 2009 10:38 PM
CalebL
22
May 15, 2008 04:50 PM
