Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Where is 93oct In K.C........
Old Nov 20, 2004 | 11:30 PM
MO_EVO8's Avatar
this sucks guy's Im moving up there and cant find any 93, it all 92 or 91. And my map is set up for 93. So if any of you guy's can help that would be kick ***. Thanks
Old Nov 21, 2004 | 05:44 PM
Compjoc's Avatar
sorry but there is no 93 octane in KC, its either octane booster or adding in some race fuel if u need the higher octane.
I use xylene in the summer months but don't need it in the winter.
Old Nov 22, 2004 | 08:25 AM
MO_EVO8's Avatar
Come on man I know there has got to be some 93oct some where. I think KC_EVO knows where some is.
Old Nov 22, 2004 | 11:09 AM
GTVEVO's Avatar
TORCO works really well, you should just buy a case and keep it with ya.
Old Nov 22, 2004 | 01:21 PM
Compjoc's Avatar
I've searched around for 93/94 octane in the KC metro area and never found any.
Old Nov 22, 2004 | 05:34 PM
MREvo_KC's Avatar
Only seen 92 at Amoco/BP stations
At least there is a station only 2 minutes from my house, at Shawnee Mission Parkway and Pflumm. That's generally what I use, unless I need gas away from home.
Then again, mine is stock.
Old Nov 29, 2004 | 04:20 AM
The Bear's Avatar
Someone told me that there is a shell station on Roe, near 435. Anyone check this out? I'll look into it more sometime this week and let you guys know.
Old Nov 29, 2004 | 06:44 PM
The Bear's Avatar
Compjoc is right. There doesn't seem to be any 93 in the area. I called alot of gas stations this evening.
I read in the manual not to use Octane Boosters, is there a reason for this?
Old Dec 6, 2004 | 01:06 PM
kcevo's Avatar
I have heard that there is a station off of 291 and Kentucky road, I think the Independence area that carries 93. It is a BP Amaco, btw I had my car tuned in Chicago on 93 Mobile gas and had no problems coming back to KC and using the 92 BP. Just check your logs for any engine knock and back off the timing accordingly, you should have the knock control turned on for safety reasons while on the pump gas map.
yellowevo82
17
Mar 21, 2015 08:27 AM
Jose_c93
Lancer How Tos / Installations
Aug 7, 2014 10:29 AM
tscompusa
Aug 31, 2013 06:40 PM
Conway_160
Aug 8, 2013 03:13 PM
evotech93
11
Nov 15, 2004 01:48 PM
