Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Moving to colorado cant find 93oct.
Old Nov 10, 2008 | 08:18 PM
whiptheevo8's Avatar
I am moving to colorado for the ski season, and was checking for 93oct. in my area but could not find any stations. so i guess i am going to re tune my car on 91oct. should i just convert to e-85? or go to 91
Old Nov 10, 2008 | 08:26 PM
P-ROY's Avatar
I am moving to that area also and there is no 93 I am prepping my car for a conversion.
if you need help check out CEVOC they are the resident experts for E85 Conversion.
Also check out CARZPERFORMANCE they are in lakewood
Old Nov 10, 2008 | 08:38 PM
word, what all exactly needs to be done to run e85
Old Nov 10, 2008 | 08:40 PM
k2boarder3187's Avatar
Convert to the E85 and never look back!
Old Nov 10, 2008 | 08:45 PM
brp's Avatar
brp
yes check out coloradoevo dot com (or CevoC as P-ROY said) and you can find all the info on e85 in colorado you need.
but to run e85 i would recommend injectors (size depends on what turbo you are running), fuel pump (double pumper if anything bigger than an FP green turbo), fuel rail, head studs so you can run high boost, and a tune (justDSM is the best local tuner and he can get you set up with that if you wish)
btw where in colorado will you be moving to?
Old Nov 10, 2008 | 08:52 PM
PeteyTurbo's Avatar
Go E-85 if you want a huge power gain..Look up the user "tobz" ..I know he is in Co. and does a great job tuning EVO's on E85
Old Nov 10, 2008 | 09:04 PM
I am moving to longmont. My cousin lives there, also I have some friends who live ski in/ ski out in breck. what kind of fuel pump should i use with the hta35r, and e85?
Old Nov 10, 2008 | 09:13 PM
linwoodm's Avatar
Good luck, I lived in KS for 3 years and had to deal with 91!
Old Nov 11, 2008 | 08:03 AM
brp's Avatar
brp
not many colorado people come on this part of the site or even evoM for that matter so it might take some time for you to get some answers here.
for a 35r and e85 you will definitely need a buschur double pumper set up. we have about 40 e85 gas stations in the state, i have not used pump/91 in just over a year now.
and i live in Boulder so only about 15minutes at the most from where you are moving to
Old Nov 12, 2008 | 01:01 AM
For sure. Do you think that 1000cc injectors would hold to 30psi, or will i need to upgrade to bigger injectors? Also is there a awd dyno any place near boulder? I have yet to get my car on one.
Thanks.
Old Nov 12, 2008 | 01:11 AM
Magnumpsi's Avatar
Yes there is an AWD dyno in boulder.
I would go 1200 just to be safe.
Mitch
Old Nov 12, 2008 | 03:49 AM
Mitch
Do you happen to know of the name of the shop that has the AWD dyno?
Thanks.
Old Nov 12, 2008 | 04:26 AM
Wicked E's Avatar
Thanks.
SuperRupair
BTW, I am the owner of CEvoC forum. Send me a PM here if you have any questions.
-E
Old Nov 12, 2008 | 07:02 AM
Joshs EVO's Avatar
I have a 35R, AEM, fully ported head, and 1000cc injectors and put down 546 HP if you move to E85 then you will need bigger injectors. I also have a double pumper system in my car. but this has already been said. But it's your car do what you like.
And I'm in CO
Old Nov 12, 2008 | 07:29 AM
And I'm in CO
So you are running on E85 with 1000cc inj.?
