04-06 Ralliart Engine/Drivetrain (no forced induction)
4G69 Information/Cross References
Old Jun 15, 2005 | 01:17 PM
senate6268's Avatar
4G6x Parts That Can Be Used in 4G69...
I had some free time today and decided to do some research. I've come up with the following:
4G69 uses 4G63 rod and crank bearings (old news)
4G69 uses 4G64, 4G94 valve guides and seals
4G69 uses the EVO timing belt tensioner which is aluminum, not cast iron
4G69 intake valve = 34mm (4G63 EVO = 34mm) May fit?
4G69 exhaust valve = 30.55mm (4G63 EVO = 30.5mm) May fit?
4G69 uses 4G64, 4G94 valve spring retainers
4G69 uses 4G63, 4G64 head bolts (can use 4G63 ARP head studs )
4G69 uses 4G63, 4G64 main bolts (can use 4G63 ARP main studs )
4G69 uses 4G63 EVO balance shafts (can use 4G63 EVO BS eliminator kit )
Nothing spectacular, I know. Every little bit helps though. Here's a good read on how Mitsubishi took a 4G64, modified it and called it a 4G69: Article. Lightened rods, lightened crank, lightened crank pulley, larger valves, shorter block height and other goodies. They did a very nice job and came out with a very nice engine.
Old Jun 15, 2005 | 10:00 PM
captain150's Avatar
So high quality/high performance internals except some of the valve train? You know where the valve springs are from?
Old Jun 16, 2005 | 12:02 AM
senate6268's Avatar
The intake and exhaust valve springs in the 4G69 are unique to that engine and don't cross reference with any other engines. The internals are very strong and can handle 10-15psi of boost on stock internals, I believe.
Old Jun 16, 2005 | 06:02 AM
Daddymac's Avatar
Thats pretty cool! Good to know. What car was the 4G94 in again? I forget.
Old Jun 16, 2005 | 06:20 AM
LancerOfOZ's Avatar
the 02-03 lancers have the 4g94. The OZ, ES, and LS.
Old Jun 16, 2005 | 08:32 AM
WoRkZ's Avatar
Question
Isn't it the 4G63???
Old Jun 16, 2005 | 11:04 AM
Jay-Eff's Avatar
4g63 is for 90-99 dsm's (1g-2g turbo talon,all laser and 1g n/t talon, 1g and 2g eclipse, 1g galant) and evo's only!
Old Jun 16, 2005 | 11:16 AM
senate6268's Avatar
The only thing I don't like about the 4G69 is that the block height is 6mm shorter than the 4G64. This brings the block height back to the same as the EVO 4G63. The 4G69 uses the same length rods as the EVO with a longer stroke of 100mm. EVO pistons, even forged ones can be used in the 4G69. However, these pistons need to be 87mm. That's the only downside. The solution is to get stroker pistons for the EVO in 87mm. 87mm pistons for an EVO, however, are not easily sourced. They more than likely would have to be made custom by JE, Wiseco, Arias, etc.
Old Jun 16, 2005 | 11:43 AM
WoRkZ's Avatar
Talking
Oups! Merci Jay-Eff!
I never new the engine was different from the EVO... I just thought they swapped some of the internals.
J'va me coucher moins niaiseux...
Old Jun 21, 2005 | 04:35 PM
senate6268's Avatar
added more parts that the 4G69 can use from other engines....bump
Old Jun 27, 2005 | 09:04 PM
403RA's Avatar
So... whats in the 04-50 OZ and ES?
Oh BTW, thanks alot for all the leg work.
Old Jun 27, 2005 | 11:19 PM
senate6268's Avatar
02-05 Lancer OZ and ES have the 4G94 2.0L SOHC engine
04-05 Lancer Ralliart has the 4G69 2.4L MIVEC engine
Old Jun 28, 2005 | 12:25 PM
KreepaEvoX's Avatar
All that cross refference...... Oh the possibilities> wait til the PR tuning guys get their hands on this info. Thanx
Old Sep 5, 2006 | 07:17 AM
senate6268's Avatar
Nothing like bringing back an old thread. But with information like this, it never hurts!
Old Sep 5, 2006 | 08:24 AM
otter's Avatar
EvoM Administrator
Added that info to the newb thread in the general section.
