Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Headlight Aim
Old Feb 2, 2008 | 05:24 PM
psxnitro's Avatar
Headlight Aim
Anyone know if there is an adjustment screw to change the aim of your headlights horizontally? I swear my left headlight is aimed too much to the right.
Old Feb 3, 2008 | 11:43 AM
Blacksheepdj's Avatar
The owner's manual just says "Contact your dealership for adjustment." So IDK if that means it's a special tool, or if they just don't want the average customer futzing with it...
Old Mar 18, 2008 | 06:51 AM
kohanson's Avatar
hi, anyone knows how? i want to try it myself instead of going down to the dealership as its far from my house..
Old Mar 18, 2008 | 10:06 AM
nunyas's Avatar
you could always just pop the hood and take a look at the headlight assembly to try and locate the adjustment screws.......... they should be pretty obvious when you see them...
Old Mar 18, 2008 | 10:50 AM
Karan's Avatar
I dont think there's any adjustment for horizontal aim. For vertical aim there is a screw there you can adjust. Its located between the highbeam and lowbeam housings.
Old Mar 19, 2008 | 07:23 AM
kohanson's Avatar
i believe i have found the knob to adjust the headlight. It should be the black knob with a silver line which i believe is a marking made by the workshop. I wonder what tools i can use to turn that. I've thought of finding a rubber maybe like a cone shape to plug it in and turn. I wonder what special tools the mitsubishi agent have to turn this thing. This image is on the front left headlamp. Any one got any ideas what i can use to turn the knob? my hand cant turn the knob.
Old Mar 19, 2008 | 07:28 AM
kohanson's Avatar
thanks for the info, i will try to look for the screws.
Old Mar 19, 2008 | 03:11 PM
kalpakiotis's Avatar
This is the picture thats in the service manual for the headlight aiming screw. Looks like a regular philips should do it, but its raining out here so im not goin ou to check. Maybe on a dry day ill pop the hood and check it out, cuz id like my headlights aimed a little higher, they suck goin through the back roads with all the up hill and down hills.
Old Mar 20, 2008 | 07:33 AM
Karan's Avatar
^ Yup thats the one. Getting a long screwdriver in there will be tricky though. Its pretty tight.
Old Sep 26, 2009 | 09:16 PM
humblehyper's Avatar
Sorry for reviving this. Does anyone know how to adjust the beam on OEM projectors for 09 Lancer GTS? I lowered my car and the beam is low now even if I set the dial to zero. Is there anyway to adjust this manually on the headlight assembly? Thanks much!
Old Nov 6, 2009 | 03:34 PM
notFSTenuff's Avatar
i tried lookin for the screw today i dont see one there. arent our headlights supposed to be staggared too?? i got hids and you can tell they are at different levels.
Old Nov 11, 2009 | 03:52 AM
psxnitro's Avatar
thought I'd share what I found out after tearing down a broken lancer headlight.
http://www.cardomain.com/ride/3003475/5
Old Nov 30, 2009 | 10:13 AM
peanutboylancer's Avatar
Registered User
one of my fog lights is burning orange instead of yellow, and idk whats wrong with it. should i just reinstall it or just go to the place i bought it from and get a new set?
Old Apr 28, 2011 | 08:04 AM
trevor's Avatar
I know this is an old thread, but I was just searching and was going to ask - does anyone know if this adjustment applies to the Evo IX? I just bought one and the headlights are basically pointed at the ground, but I haven't had the chance to look under the hood to see if there's an obvious vertical adjustment for them.
I know you can adjust the height of the headlights from inside the car, but I think the motor is dead, because that little switch doesn't do anything. I'm afraid I may have to replace the switch altogether, but I'm not sure yet.
Any help is appreciated!
Trevor
Old Apr 29, 2011 | 03:58 PM
mike389's Avatar
Uh our headlights are different but most headlights have a screw that aims the lights, try your service manual... I have adjusted my headlights before and its pretty simple
honda-guy
Jan 29, 2016 12:44 PM
Jp7
Oct 7, 2014 01:06 PM
Nicker31
Aug 17, 2012 02:30 PM
stunt2
May 14, 2011 12:36 AM
XLR8R
Nov 8, 2010 12:02 AM
