cobb AP and boost
Old Feb 26, 2009 | 04:47 PM
mooserov's Avatar
cobb AP and boost
I'm running a stage 2 map on my ap and found something odd watching my boost gauge. The boost peaks at 24/25 and settles down to 17/18 psi, like it's supposed to do. But, on the way to 25, it stops at 15psi for a few seconds. looks like it hangs there from 4000 to 5500. The z-chip would go all the way to peak without any pauses.
Has anyone else seen this?
Going to be selling my z-chip for $200 also.
Old Feb 26, 2009 | 04:52 PM
LVSBB6's Avatar
interesting, have you contacted Cobb about it?
Old Feb 26, 2009 | 04:57 PM
THEMEMPHISFORCE's Avatar
How does that map do with your AEM intake? Or is that a custom stage 2 map? Just wondering....Also I would give cobb a shout.
Old Feb 26, 2009 | 05:00 PM
mooserov's Avatar
haven't contacted them about it yet, just noticed it about 30 minutes ago. I am running the stage 2 map intended for cobb's intake. I am not having any problems with it, no knock counts and not running lean.
I'll contact cobb tomorrow.
The z-chip was a great product, I just wanted to have the added security of the stock boost control system if any problems arised, if anyone was curious.
Old Feb 26, 2009 | 06:19 PM
Wicked X's Avatar
Yea when we dynoed our Evo x we noticed this on the dyno but it only occured once out of 5 runs. We have noticed that the hotter the car gets the more it fills like the turbo just isn't building boost.
Old Mar 5, 2009 | 11:21 AM
mooserov's Avatar
Fixed it. I had my boost pill on the wastegate side instead of the turbo outlet side. Installed it backwards when I removed my mbc and Z-chip. Swapped it today at lunch and it made a huge difference.
Old Mar 6, 2009 | 07:36 AM
monchy's Avatar
Is it worth to get that cobb ap to get a good tuning for a guy like me who don't know nothing about tuning? I know there is a lot of feutures on the cobb ap but i'll like to get the more horses possible
Old Mar 6, 2009 | 01:38 PM
mooserov's Avatar
all i did was flash the stage 2 map that came with it. You don't need to know anything about tuning to use this. I prefer this type of solution because it retains the stock boost control system.
Old Mar 6, 2009 | 02:37 PM
Scottyb's Avatar
Registered User
i had the zchip and it ran wayy too lean! which is not a good thing for a guy like me. that chip is so hard to tune! i got accessport this weekend and its 100 times better! deffinately worth it! cobb is doing a custom tune for me. but they still have those preloaded maps. i gained 45hp just using the stage 2 map. then they started tuning from there
Old Mar 9, 2009 | 08:47 AM
monchy's Avatar
Ummm; that cobb ap sounds interesting
Old Mar 9, 2009 | 10:25 AM
TTP Engineering's Avatar
You gained that or more with the ZChip alone according to the dynosheet you sent us.
Tailpipe sniffers are not very accurate, and when you have a competing product manufacturer dynoing and testing your car, you have to take their bashing comments of the competing product with a grain of salt.
Old Mar 9, 2009 | 01:18 PM
LVSBB6's Avatar
Just wanted to make sure I understand correctly. You removed the incorrect boost pill at first and thats why you ran into the problem?
Old Mar 9, 2009 | 03:54 PM
EvoG8r's Avatar
I saw that dyno sheet while I was getting tuned at cobb. It happened to be laying on someones desk and I saw the AFRs and all I can say is yikes. I askedthem about it... from what I understand is that someone else may have tuned it after Scott sent it out so I'm not sure z-chip was to blame on that one. Cobb wasn't too up on the z-chip and they really didn't care one way or the other about the chip anyway. They are a very professional group.
Old Mar 10, 2009 | 06:48 AM
mooserov's Avatar
I removed the entire network of hoses that had the pill in it to install a Manual boost controller. When i went back to stock, I swapped the Wastegate and turbo-outlet ends. It worked, just oddly. Swapped it back and all is good now.
ksattic
26
Nov 1, 2011 04:40 PM
evodave
15
Jul 8, 2010 02:12 PM
GiLizILL
Mar 31, 2009 10:52 AM
GiLizILL
Jan 15, 2009 11:39 AM
tsitalon1
20
Dec 7, 2008 07:09 AM
