Where to pull Speedo and Engine RPM signal from?
Old Apr 1, 2009 | 11:43 AM
Chebosto's Avatar
Is there a speed signal and / or seperate Engine RPM signal on the X's ecu?
since it's CAN based i'm thinking most likely not. are people just using first ignition coil for RPM speed and setting their gauges to single signal input?
thinking about installing Defi guages.. thanks
Old Apr 1, 2009 | 11:58 AM
boostin20's Avatar
You gotta get an engine performance wiring diagram that shows ecu pinout. The rpm will work off of a pulsating ground from the coils and the speed can be taken from vss input wire at ecu.
Old Apr 1, 2009 | 01:46 PM
Chebosto's Avatar
Thanks!!
trying to get me the service manual in PDF.. its hard to locate..
Old Dec 21, 2009 | 07:47 PM
villero1834's Avatar
is not gonna work our voltage signal is not 12 volts but less cuz we dont a an actual distributor , we have a coil per cilinder type of ignition
Old Dec 21, 2009 | 08:41 PM
Evolutionary1's Avatar
This has been discussed and found in a different thread for the HKS turbo timer type 1. Here is the link for those wires.
https://www.evolutionm.net/forums/ev...o-timer-2.html
Old Dec 22, 2009 | 10:26 AM
Guru's Avatar
https://www.evolutionm.net/forums/ev...et-navi-2.html
I posted pic on there. Here are pinouts:
http://roadraceengineering.com/evox/...-ecuwiring.htm
Had to do em for the AVCR install. Make sure to grab a coil signal for RPM.
r4p.t0x
Feb 7, 2017 10:48 AM
RST_89
Aug 11, 2015 07:15 AM
Thom93
Nov 13, 2014 11:41 PM
polish_pounder
May 6, 2012 08:14 PM
darkstarbd
Nov 26, 2011 02:42 AM
