Throwing P0137 and P1235 after EBC
Old Aug 16, 2009 | 03:07 PM
Meth Addict's Avatar
Added an EBC and now I'm throwing these two codes. I know what they are but does anyone know how to properly tune them out with EcuFlash? Should increasing the percentages of airflow check 1-3 do the trick? Any help would be appreciated. I'm going for a dyno tune in roughly a month so I just need something to get me by in the meantime without throwing the same codes every day.
Old Aug 16, 2009 | 03:58 PM
tephra's Avatar
yup add some to your airflow checks (at the right rpm/tps) obviously
isnt P0137 rear02?
Old Aug 17, 2009 | 05:54 PM
coevolve's Avatar
For some reason I can't link the thread but head over to evoxforums, there's some great information there as well as here using the search function
https://www.evolutionm.net/forums/ev...1245-code.html
Old Aug 17, 2009 | 08:57 PM
Hiboost's Avatar
Just be sure to increase them only as much as you need, going too high will trigger the "low airflow" SES which severely cuts back on how much boost you can run when it triggers. When exceeding airflow limits the result has always just been a 2k idle and maybe slightly lower performance.
The other option is to just disable the tables all together, something I plan on doing tomorrow after what happened to me at the Buschur Shootout this last weekend.
Old Aug 19, 2009 | 06:05 PM
Tried changing the tables, even disabling the tables doesn't work.
Dwilson36
May 5, 2016 11:05 AM
lil_town
Oct 14, 2013 10:45 PM
stefano
Feb 22, 2010 10:21 PM
spooch
12
Feb 11, 2008 07:54 PM
spoonerr
Oct 11, 2007 11:38 AM
