Can't find the MAF table anywhere in ECUFLASH
Old Aug 19, 2009 | 07:56 PM
LIGHTSPD's Avatar
Can't find the MAFF table in ECUFLASH at all. Has anyone done the disassembly so I can add this in. Or for that matter even just know the address where it is located I can do the rest.
Cheers
Old Aug 19, 2009 | 08:04 PM
xPRimNT's Avatar
Cam?
Enjoy
GSR (I don't have the MR one, but I'm sure it's here somewhere)
Evo10base.xml
Code:
    <scaling name="MAFVoltScaling" units="units" toexpr="x*5/1024" frexpr="x*1024/5" format="%.3f" min="0" max="5" inc="1" storagetype="uint16" endian="big"/>
    <table name="MAF Compensation" category="Fuel" type="2D" scaling="AirFlow16">
        <table name="X" type="X Axis" elements="40" scaling="MAFVoltScaling"/>
    </table>
    <table name="MAF Compensation #2" category="Fuel" type="2D" level="1" scaling="AirFlow16">
    </table>
    <table name="MAF Compensation #3" category="Fuel" type="2D" level="1" scaling="AirFlow16">
        <table name="X" type="X Axis" elements="50" scaling="MAFVoltScaling"/>
    </table>
52680015.xml
Code:
    <table name="MAF Compensation" address="5753a">
        <table name="X" address="615ea"/>
    </table>
    <table name="MAF Compensation #2" address="5758a">
        <table name="X" address="6163a"/>
    </table>
    <table name="MAF Compensation #3" address="575da">
        <table name="X" address="6168a"/>
    </table>
Old Aug 19, 2009 | 08:20 PM
LIGHTSPD's Avatar
Thanks man tuning a large turbo X and was having trouble with Cobb and P codes so I thought I would give this a go.
Old Aug 19, 2009 | 08:24 PM
LIGHTSPD's Avatar
Thanks for those how about the MAP sensor calibration tables. Or even better yet does someone have a dissassembly thye would like to share.
Old Aug 19, 2009 | 10:36 PM
xPRimNT's Avatar
Sorry, don't have those ones! Good luck though.
Old Dec 10, 2009 | 03:15 AM
TJung's Avatar
Will it work on Evo 9? Maybe someone has to Evo 9 this settings ?
Old Dec 10, 2009 | 06:53 PM
mrfred's Avatar
Back when I was fiddling with Evo 10 disassem, I could not find a link between the code and the MAF table. I only found it by virtue of knowing what it should look like. There's probably an indirect reference to it. Maybe tephra has since traced it out.
Old Dec 10, 2009 | 09:36 PM
HB Speed's Avatar
cam drop me a PM i can help you with that
Old Dec 11, 2009 | 11:22 AM
Oracle1's Avatar
after adding bigger turbo, which parameters need tuning to avoid CEL?
I think the error code is related to airflow, I gues too much of it.
Any ideas, help please.
Old Dec 11, 2009 | 12:02 PM
Clipse3GT's Avatar
Torque and Airflow limit tables...
Old Dec 11, 2009 | 03:17 PM
Oracle1's Avatar
what should it be increased to?
Any examples?
Old Dec 13, 2009 | 05:20 AM
kozmic27's Avatar
Any examples?
My torque and airflow tables on the stock turbo are up over 30% from stock. This 30% is roughly the same as the power increase the car is making over stock.
Old Dec 13, 2009 | 01:18 PM
boostin20's Avatar
sub'd
Bob_tm
Jan 5, 2018 04:45 AM
redSLed
Jan 2, 2018 12:04 PM
Raceghost
Nov 23, 2016 10:17 PM
bevolucion
Jul 9, 2010 02:23 PM
mrfred
Apr 1, 2009 05:00 PM
