Cobb stage2-93
Old Dec 10, 2009 | 10:59 PM
xhomm02's Avatar
Cobb stage2-93
I am running full turboback with HFC, KN drop-in filter, otherwise stock.
I am hitting 27psi during 4th gear pull. I have pushed the restrictor pill back to the line, but the same result (in log).
Could someone advice how to make it lower (up tp 25-26psi). Should I lower the WGDC course or WGDC fine or other table?
Thanks,
Martin
Old Dec 10, 2009 | 11:03 PM
Clipse3GT's Avatar
You can lower your 3 Boost Target tables in the spot where you are overboosting . I am going to assume 3000-4500 range @ above 80% TPS. Lower it by like 5 units of load and see where that gets you, adjust up or down to fine tune the results.
Old Dec 11, 2009 | 12:27 AM
xhomm02's Avatar
Thank you, I will try. I added the log file.
File Type: txt
Old Dec 11, 2009 | 05:48 AM
xhomm02's Avatar
I lowered all the 3 boost tables to max 248 target load, but if you look at the log of 3rd gear, I reached 270 load at 27 psi and the engine did not go smooth, it was like a few fuel cuts or any other tq limiting during the pull.
What am I doing wrong?
Old Dec 11, 2009 | 06:16 AM
uranium9v's Avatar
I know on the AP for Mazda, you adjust load tables to change boost targets. Is it the same for the EVO?
Old Dec 11, 2009 | 06:43 AM
xhomm02's Avatar
Seems to be the same, but load I reach is much above target in tables..
Old Dec 14, 2009 | 09:58 AM
xhomm02's Avatar
Solved.
I dovnloaded new map versions from Cobb and suddenly everything work¨s fine! :-)
PL_MR
Aug 11, 2020 08:14 PM
tenney
May 12, 2016 03:29 AM
Cbr1000love
Apr 15, 2016 08:03 AM
HornstarBU
Oct 20, 2011 09:03 PM
razorlab
Mar 20, 2008 11:28 AM
