Sponsored by:
Sponsored by: CARiD
U0100 and C1617, car won't start
Old Dec 28, 2012 | 03:13 PM
ahendrickson's Avatar
Exclamation U0100 and C1617, car won't start
So I just drove my car about 500 miles up to Vermont. It made the trip no problem and I had no issues with the drive up here. As soon as I got here, I parked the car and unloaded my bag. There was about 9 inches of snow on the ground, so my front bumper was acting as a plow, pushing a bit of snow.
I tried to leave about 10 minuets later. I started the car up and it turned over fine. I went to back up, and since I was a little stuck in the snow, it stalled. I tried to turn it on again, and nothing. It wont even try to crank, and all the check engine lights cycle through on my display (ie. check battery, check oil, check coolant, check engine, check AWD.) I take out my Accessport and try to pull the codes. The only codes that come up are ACD: U0100 and C1617.
I tried unplugging the battery and letting it sit for about 10 minuets but it did nothing. I tried to clear the codes with my AP, but it said that it could not communicate with the ECU. As far as mods go, I have a MAPerformance EF2 turbo charger, injectors, TBE, fuel pump, intercooler, and all the other supporting mods. It's a 2008 GSR with about 53,000 miles on it.
Please help!!! Can't be stuck in VT.
Old Dec 28, 2012 | 03:31 PM
Iowa999's Avatar
You're probably freaking, so here: https://www.evolutionm.net/forums/ev...c1617-wtf.html In summary, your ECU has lost all communication.
Old Dec 28, 2012 | 03:37 PM
Yeah, I tried to use my AP to clear the codes and even reflash back to stock, but it cant communicate with the ECU, like you said. Any fixes?
Old Dec 28, 2012 | 03:52 PM
FastAttack's Avatar
disconnect your battery ,
double check the connections to your ECU.. plug battery back in..
try and see if the communication link comes back up.
Old Dec 28, 2012 | 04:07 PM
Checked, and the connections were good. Still nothing.
Old Dec 28, 2012 | 04:44 PM
FastAttack's Avatar
did you disconnect the battery???
Old Dec 28, 2012 | 06:07 PM
Iowa999's Avatar
It's soooo tempting to write "did you try reading the third paragraph of the first post???" but I've been told by my supervisor (Noize) to chill on the sarcasm, so I won't. tee hee
Old Dec 29, 2012 | 08:58 PM
FastAttack's Avatar
your right , actually i should have been slapped.. that's what i get for speed reading at work
Well if its not communicating by now.. I would disconnect the battery.. oh crap I am doing it again. lol
The OP hasn't posted so I am guessing he fixed it.
If he hasn't maybe the stealership will take care of it.
Old Jun 6, 2015 | 05:31 PM
MrJoshH's Avatar
Did you ever figure out how to fix this? I'm having the same issue now....
Old Jul 23, 2015 | 06:34 AM
jbrownfz's Avatar
Im having the exact same issue as well
Old Jul 23, 2015 | 06:46 AM
Napalm_Enema's Avatar
Did you disconnect the battery, as suggested?
Old Jul 23, 2015 | 02:55 PM
jbrownfz's Avatar
yes I tried that And also checked all my fuses/relays. No dice.best i can figure is my ecu somehow locked out
Old Jul 24, 2015 | 06:27 AM
obake214's Avatar
Just some friendly info for anyone, the ECM is covered under Federal Emissions warranty for 8years/80k ( any manufacture ) but with mods not sure if the dealer would replace it under the warranty.. wont hurt to ask a dealer that is mod friendly.
Old Jul 25, 2015 | 01:21 PM
jbrownfz's Avatar
Thanks for the info but mine has just over 90,000 miles on it... The dealership is still trying to work out the issue. I wish I knew what could've caused this.
Old Nov 4, 2020 | 10:10 PM
defaulthiding's Avatar
Anybody get it solved?
DaRw1n
Oct 21, 2016 05:51 PM
FRESH.I.AM
20
Jul 15, 2016 07:12 PM
ApexVIII
Dec 15, 2015 10:45 PM
dragon831
Jun 6, 2015 05:30 PM
EvoDom
14
Dec 11, 2011 08:47 AM
