EBC on SST
Old Feb 15, 2009 | 04:13 AM
Yousef's Avatar
EBC on SST
hi
just called my local performance shop to ask about HKS EVC 6.
they said it does not work on SST
anyone here with EBC on SST??
I've seen a video on youtube, Blitz i-Color on SST, im not sure if the guy used a work around of it worked out of the box!
thanx
Old Feb 15, 2009 | 05:42 AM
Robevo RS's Avatar
how about the A'pexi AVC-R ? But if that doesnt do it, the Ecuteck tune controll the boost through the factory ECU set up.
And does a phenomenal job So if you get tune by them you set for your boost problem. Get a boost pill + Forge WGA and the Ecuteck tune , and you will be blown away
Old Feb 15, 2009 | 06:50 AM
Yousef's Avatar
i got zchip but it needs high boost, i have MBC but not sure!! i prefer EBC
Old Feb 15, 2009 | 07:14 AM
Robevo RS's Avatar
i just realized it
Yeah i think the A'pexi AVC-R or the HKS EVC 6 is a better option.
Just make sure you install it right and set it up right.
It takes longer but then you never have to take a look on them again.
Old Feb 15, 2009 | 07:22 AM
Yousef's Avatar
HKS EVC 6 does not work on SST, my local performance shop said
Old Feb 15, 2009 | 07:34 AM
Robevo RS's Avatar
why not? its messing up the TC-SST-ECU?
http://i184.photobucket.com/albums/x...echanism_1.png
Old Feb 15, 2009 | 08:20 AM
philamthebest's Avatar
The EVC does work.... not sure why they said that. The wiring is complicated but it can be done. remember the MR has a dual solenoid as stock, so you have to get a dual solenoid bc.....
Old Feb 27, 2009 | 06:08 AM
MR-X1212's Avatar
I have HKS EVC 6 on my MR. works great, no problems at all. get a second opinion. because it can obviously be done, and work well.
Old Feb 27, 2009 | 06:28 AM
chueu's Avatar
Old Feb 28, 2009 | 09:05 PM
Yousef's Avatar
updates
https://www.evolutionm.net/forums/ev...e-warning.html
Old Mar 1, 2009 | 04:59 AM
Robevo RS's Avatar
the GSR have a same solenoid valve too.
