SST Shifting at Rev Limiter
I have posted this in the other forum a while ago but got no response hoping this time others are having the same issue. When in Auto Sport Mode 2nd gear upshift at WOT the engine revs straight to rev limiter 7500 before it shifts. Does not do this in normal or S-Sport. Mods: AEM intake, Greddy DP, AP Test Pipe, AP Exhaust, Cobb AP Stage 2 w/pill removed. Today installed stock intake, installed pill, installed stock map still no change. Really getting frustrated.
How many times have you done this without reflashing? The car has to learn when to shift. It knows about how long it takes to get to 7500 stock. Every time you reflash or reset your ecu, it forgets. It will take about 4-6 times running wot to redline before the car learns how to shift again. I have had this happen many times, and each time, it takes a few runs for the car to learn how to shift again.
If you reset your ecu, and you car is not stock, it will hit the rev limiter before shifting if you go all out the next couple of times, at the drag strip for example. This is normal. Once the tcu figures it out, it stops doing it.
HELPr
Apr 19, 2012 08:19 PM
