SSP - Pro Gold DCT Fluid
Old Jan 17, 2011 | 12:37 PM
  #31
madfast's Avatar
^^^ reminds me of the "this is your brain on drugs" commercials...
Old Jan 18, 2011 | 11:04 AM
  #32
SSP Jeremy's Avatar
^^^ I hope I wasn't that dramatic,lol.
Old Jan 19, 2011 | 09:28 AM
  #33
kmart888's Avatar
Originally Posted by saytheb
I can confirm this as well. Previous version of the manual suggested a mineral oil flush. New manual has removed this reference.
Mitsu never recommended "mineral oil", not far as I can find! Another internet myth I think!
Every time I read "Mineral Oil" I think of the lineament you buy at the drug store , that stuff cost more than SSTF 1!
2010 MR-T (SST)
Stock clutch packs
OEM DiaQueen SST fluid
SSP trans Deep Sump
SSP Front mount trans cooler
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
WORKS tune using OP (cleaned up by Bryan)
Green relay (yeah that’s it, it MUST be a faulty fuel pump relay!)
Old Mar 2, 2011 | 08:13 PM
  #34
wthoevo8's Avatar
Originally Posted by SSP Jeremy
I'm running Pro Red in my X MR, and Pro Gold in my GT-R. I'll be switching over to the Gold in my Evo over the winter.
I'll post it up soon as Kris gets back in town.
Any update on the Pro Gold in the Evo???
Old Mar 23, 2011 | 05:35 PM
  #35
EVO-J's Avatar
In for updates and also I heard SSP was suppose to come out with a reusable SST filter. Any word on that?
Old Mar 24, 2011 | 05:23 AM
  #36
mrMTB's Avatar
You mean this?
http://www.sspperformance.com/produc...roducts_id=153
Old May 18, 2011 | 05:39 PM
  #37
mission664's Avatar
can the ssp gold go into a evo IX MR tranny?
Old May 23, 2011 | 05:40 AM
  #38
10Sportback's Avatar
Waste of $
I did my transmission fluid change over the weekend at 14K w/ Diaqueen and realized it is a waste of money. The fluid was in good condition and I don't notice any difference in shifting (not that I had problems before). The filter looked good, and oh BTW Diaqueen is green so as soon as any fluid passed thru it will turn from white to green. I wont' even touch my tranny fluid for at least another 45K miles.
Old May 23, 2011 | 10:48 AM
  #39
SSPKris's Avatar
Our Pro Gold transmission fluid cannot be used in a manual gearbox.
SSP
Old May 25, 2011 | 04:06 AM
  #40
richardjh's Avatar
Looking at it from another viewpoint, you changed your fluid before it was degraded.
Rich
Old May 26, 2011 | 09:20 PM
  #41
kozmic27's Avatar
The original flush recomendation from Mitsu was with Diaqueen. I recommended mineral oil because of the fact that Diaqueen is $150 per gallon, versus mineral oil, wich is fairly inexpensive. The reason I use mineral oil is because it basically inert, will not adversly react with any other oils, has a relatively low viscosity and drains well. Mineral oil is a common in service flushing fluid for a variety of applications and industries, including aviation for this same reason.
Regarding changing the oil sooner than the recomended by Mitsubishi 50k interval:
At 8k miles, the fluid in my SST came out a muddy brown. Upon removing the filter, I found casting sand in the filter. My reason for recomending that SST fluid be changed for the first time very soon is the fact that the majority of debris/contamination I have seen in several SST's appears to be break in/manufacturing related. After the initial fluid change, it seems that the fluid stays clean for much longer. Nissan recomends that the GR6 transmission have its tranmission fluid inspected at 12k miles, and replaced at 18k miles. This interval seems more reaonable for the life of the tranmission than letting the fluid turn to mud.
10Sportback, you did not waste your money. Preventative maintenance is NEVER a waste of money.
2010 MR-T (SST)
Stock clutch packs
SSP trans Deep Sump
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
Old May 27, 2011 | 05:25 AM
  #42
After thinking about it and with the weather getting hot I'm glad I'm running the fresh stuff in my tranny and also to know that I didn't have the issues other people had. I was also wondering 2 things. Does the Pro Gold perform better in heat, and should I use the old Diaqueen for the flush next time?
Old May 27, 2011 | 02:52 PM
  #43
luvboost's Avatar
Rich
x2, give it 30,000 and you'll see what used trans fluid really looks like. Mine was changed at 30,000 and the original owner said it was definitely dirty and probably should have been changed a bit sooner. I'll be changing mine in the next 15,000 miles.
Old Dec 17, 2011 | 07:14 AM
  #44
sparky's Avatar
..... should I use the old Diaqueen for the flush next time?
Define "old" please. Are you suggesting flushing the transmission with the same used, dirty oil that you just drained from your tranny? This doesn't make any sense to me!
Old Oct 20, 2012 | 09:37 AM
  #45
SSP Jeremy's Avatar
SSP Pro Gold is a high-tech transmission fluid developed from the latest base oil and additive technology. Created especially for the newer DCT transmissions, Pro Gold exceeds clutch friction and wear protection requirements for all DCT transmissions. Pro Gold fluid is a extreme performance synthetic fluid suitable for use in all DCT set ups, and is specially formulated to protect your transmission in daily driving to full Race applications.
Our Price - $ 200.00 (4 liters)
http://www.sspperformance.com/produc...er-container-/
