Light throttle, clutches opening
Old Feb 8, 2011 | 06:00 PM
Piper747's Avatar
I was hoping someone might have some insight into this phenomenon. Today as I was lightly accelerating with about 15 - 20% throttle, and as I shift from 2nd to 3rd, just as third engages the clutches open up and the engine revs. The car was at normal operating temperature. This does not happen often, but it is not the first time it has happened. Its kinda cold here, about -12 C, and it seems to happen mostly in cooler temperatures.
I was thinking that I had exceeded the torque limit for that little throttle. I can hear the car use the lower bound timing in between shifts and was thinking that maybe it is building unnecessary boost at this light throttle from the much retarded ignition timing in that area of the lower bound map. I'm hoping to understand the purpose of the lower bound timing in the indicated area. Why is it so much lower than the timing that would be used in the high octane map? This is from one of the GST base maps, but the factory rom is even more retarded.
Has anyone had a similar issue?
Old Feb 8, 2011 | 09:43 PM
RazorLab's Avatar
You should upgrade to the new basemap V2.5
Old Feb 9, 2011 | 06:08 AM
Piper747's Avatar
lol. I was wondering what kinda of good stuff was going on behind the scene in those maps.
Ill copy over some maps that are different and give it a try. Thanks Bryan!
Old Feb 9, 2011 | 05:18 PM
Piper747's Avatar
You are indeed a master at your craft!
It wasn't as cold today, but the car did feel MUCH nicer with light throttle shifts.
moparfan
Mar 18, 2021 10:28 PM
Masheen
Nov 21, 2013 02:52 PM
Piper747
75
May 24, 2012 06:12 PM
Kaizen Tuning
Mitsubishi TC-SST Discussion
Jan 1, 2012 03:31 PM
Clipse3GT
Oct 31, 2010 12:46 PM
