SST making weird noises after fluid change
I couldn't find the problem anywhere so i figure i'll make a new thread.
I changed my Transfer Case and Rear Diff oil and installed my downpipe on friday and this morning (saturday) i started the car and there was a weird grinding noise coming from the engine bay passenger side. Also when i take off from 1st (dead stop) i'll hear the same grinding noise. any help is greatly appreciated.
p.s. the car drive and shift fine other then the noises on start up and from a dead stop, car still pull hard through all 6 gears.
Grinding noise
If it's a bad betal scraping sound it could just be a rock stuck in your bake shield, or the shield go bent when you removed wheels. It can them come and go as shield changes temp. Very common.
cool i'll check it tomorrow.
i actually notice that the sound is in sync with exhaust tone, like when i go from P to R the exhaust tone and rpm rises and that's when i here the scraping noise. so it got me thinking the downpipe might be loose or scraping against something.
king_cas
Jul 9, 2016 10:13 PM
High_PSI
Sep 15, 2007 09:31 PM
Gobi
Jan 21, 2004 01:39 PM
