Evo X MR SST PROBLEM **PLEASE HELP**
Old Jan 18, 2013 | 01:17 PM
JLR-AWD's Avatar
Sst
If they took apart/open the tranny to check the clutches there is a seal that if install improperly causes the tranny to not function at all, it will not engaged any gear. Besides that, they would have to check all components, censors, lines and filter to find out the problem. Good luck!
Old Jan 19, 2013 | 07:52 AM
skazoura's Avatar
Hey guys sorry for the lack of update, so after checking all the components, they decided to swap the ECU. The car finally worked. The mechanic told me there was a problem with my ETACS
Old Jan 20, 2013 | 11:54 AM
JinxsEvoXMR's Avatar
good, glad you at least got it running again.
Old Feb 20, 2013 | 03:44 PM
xevoxx's Avatar
wtf awesome
Old Sep 17, 2014 | 07:37 AM
TEXAS05EVO's Avatar
OP,
Did they explain to you what the issue was with the ETACS? My 2013 MR 18k miles (no aftermarket parts) is also having this issue randomly when i get in the car Drive, Reverse or any other gear will not engage then if i hold the throttle down to 1500rpm the gear will JERK into gear and be fine i have taken it too 2 local dealers and they both have said they were unable to duplicate the issue and were unwilling to investigate further until they can duplicate the issue. They said to keep driving it until the issue becomes common?!?!? WTF !>!>! they will not even check the transmission fluid
Jigga12
Mitsubishi TC-SST Discussion
101
Apr 9, 2020 11:21 PM
yodizzle
Mar 3, 2017 05:25 AM
tsizzle
Oct 8, 2016 12:07 AM
Peage
Jun 20, 2016 11:33 AM
Evol Darwin
Sep 25, 2014 12:19 PM
