SST Technical Guide & Rebuild Kits HERE
Old May 20, 2013 | 08:03 PM
EyeDreamt's Avatar
Figured it's time I share this stuff openly.
First up is the ATSG Technician Guide for the SST (DCT470). This contains TONS of very technical information such as solenoid functions, wiring diagrams, valve body mappings, etc. The SST stuff starts on page 45.
http://www.filedropper.com/getragtg
Next is rebuild kits and replacement parts for the transmission from Precision International. Not sure how good or bad their friction discs and other parts are, or if they may even be OEM, but they have them.
http://www.transmissionkits.com/imag...M%20SOLVER.pdf
And last is this, which I think is a diagram of the SST I received from a mitsubishi oem parts supplier. I have ordered some parts to test the legitimacy of the information before sharing the part numbers openly.
Old May 20, 2013 | 08:15 PM
SaulHudson's Avatar
Um kind of confused. Their parts only fit 09+ evos and 11+ ralliart or are they just idiots and have no idea what year or model names the trans came in?
Old May 20, 2013 | 08:26 PM
EyeDreamt's Avatar
The second is more likely.
Old May 20, 2013 | 08:33 PM
SaulHudson's Avatar
I can't possibly trust a company which can't take 10 mins to research what model and years the transmission they are making Chinese parts for came in.
Old May 20, 2013 | 08:36 PM
EyeDreamt's Avatar
These aren't performance parts, and aren't directed at the public. These are kits for local transmission shops to be able to rebuild the the thing. Those shops don't look things up by car make model year, they look it up by transmission part number. An Precision International provided s LOT of kits for a LOT of cars. This is all they do.
Old May 20, 2013 | 08:44 PM
gaabbee's Avatar
This place is 10 mins from me. Did you want me to go and ask some questions in person?
Old May 20, 2013 | 08:50 PM
EyeDreamt's Avatar
Yeah! I'd love to know pricing, and if you can get it out of them, how much harder/softer, etc their discs are than OEM, as well as who actually manufactures them if they don't.
Old May 24, 2013 | 12:21 AM
KozmicMotorSpts's Avatar
We stock the following parts for the Getrag DCT 470 (SST) Transmission. We also have some items not listed from opened Master Overhaul Kits. These won't be listed, but if we have a part in an incomplete kit, we will sell it, otherwise we will not break a kit. Prices and availability are subject to change without notice. The master overhaul kit is on our web site, as are some other parts, but not our online store. So to buy these now, you will have to contact us directly. This will change, but as of right now, we have not had time to get these loaded into the store. Items in bold are the most common items people will need for routine service or common issues. I know this isn't the most forum friendly as it is pasted from a quick books report. Basically if you need an SST part, and it is available from somewhere, we have it or can get it. We attempt to keep all of the parts on this list in stock at all times.
NOTICE: NONE OF THESE PARTS ARE INTENDED AS PERFORMANCE UPGRADES!! THEY ARE INTENDED AS REPAIR OR SERVICE ITEMS ONLY. WE MAKE NO CLAIMS REGARDING ANY OF THESE PARTS ABILITY TO EXCEED OEM POWER LEVELS!
effective 8-16-2013
K27 DCT470 2.2SP Steel End Plate (2.2mm) 0.00
K27 DCT470 ASC-1 M/C Seal, Axle (Converter) (also requires K27 DCT4... 12.93
K27 DCT470 ASC-2 Seal, Axle,Converter Side, inner, Getrag DCT470 (A... 19.80
K27 DCT470 ASC-K Output Shaft Seal (axle seal), Converter (T-case) sid... 31.23
K27 DCT470 ASD M/C seal, axle, DCT 470 (Differential) 13.20
K27 DCT470 CMK-E Economy Friction and Steel Module kit for Getrag D... 741.00
K27 DCT470 EF DCT470 external filter (SST) FILTER ONLY (Bowl g... 36.57
K27 DCT470 EFG O-ring, filter bowl, DCT 470 (SST) 5.20
K27 DCT470 EFHCS Gasket, external filter housing, DCT 470 9.75
K27 DCT470 EFK Kozmic Motorsports DCT470 (SST) External Filter K... 36.57
K27 DCT470 ERP FSK Kozmic Motorsports DCT470 (SST) Ecconomy Rac... 1,672.04
K27 DCT470 FME Economy Friction Module, Getrag DCT470 (clutches... 370.00
K27 DCT470 HUB ORING O-ring, hub shaft, DCT470 ( SST) 5.52
K27 DCT470 MF DCT470 internal filter (SST) Main 36.57
K27 DCT470 MOHK-STD Master Kit, DCT470, w/piston and front cover. Includ... 1,659.65
K27 DCT470 MPS-1 Molded Piston (Clutch Seals), Getrag DCT470 (SST... 48.65
K27 DCT470 MPS-2 Molded Piston (Clutch Seal), Getrag DCT470 (SST) ... 73.10
K27 DCT470 MSS M/C seal, Manual Shaft (Shift lever) DCT470 13.50
K27 DCT470 MVBGL Gasket, metal, V/B to case (large), DCT470 25.50
K27 DCT470 MVBGS Gasket, metal, v/b to case, (small) DCT 470 22.92
K27 DCT470 NVBCB Checkball, Nylon, DCT470 1.65
K27 DCT470 OHK Overhaul Kit, SPS6, DCT470, W6DGA 2009-12 min... 742.00
K27 DCT470 PG Pan Gasket, DCT470 (SST) 23.10
K27 DCT470 PVBG0 Gasket, V/B to case upper, DCT470 (valve body inte... 15.90
K27 DCT470 PVBG1 Gasket, V/B to case Lower DCT470 (Valve body int... 15.90
K27 DCT470 SFPL Molded Piston, shift fork, large DCT470 20.40
K27 DCT470 SFPS Molded Piston, Shift fork, (Small), Getrag DCT470 19.50
K27 DCT470 SM Steel Module, DCT470, standard. (Will NOT work wi... 371.00
K27 DCT470 SSRK Kit, Stator Ring Seal DCT 470 280.00
K27 DCT470 VBSCB Checkball, steel, DCT470 2.78
K27 DCT470CCSPK Kozmic Motorsports DCT470 Clutch Compartment S... 499.99
K27 DCT470ERP Kozmic Motorsports Ecconomy Race Pack Clutch Ki... 1,172.05
K27 DCT470MPK Molded Piston Kit for Getrag DCT470 (SST). (Does ... 275.21
K27 DCT470SG Gasket, Stator, DCT470 5.20
Last edited by KozmicMotorSpts; Sep 6, 2013 at 11:08 PM. Reason: updated part numbers and pricing
Old May 24, 2013 | 12:27 AM
Considering the parts are listed in their parts catalog by the transmission part number AND the makes and models this transmission is used in, I don't think you have anything to worry about there. Their filters, seals, and gaskets are extremely high quality, and some of the parts that they carry are not obtainable from any other source.
Old Sep 6, 2013 | 07:00 AM
Stasiu's Avatar
I'd be interested in taking a peek at these files, but can't get it to download. Anyone willing to e-mail the pdf to me? It'd be much appreciated!!
Old Sep 6, 2013 | 07:24 AM
Mani8448's Avatar
@ Kozmic
Do you guys also service the TC-SST in house here in Houston?
Or do you just sell the parts?
I have been keeping up with the TX mile Evo MR, Kozmic etc. and once I take the plunge I would love to have you guys do all the work on my 2012 MR.
Transwork will not be for a long time - taking it slow - but it would be nice to know there is another shop, besides dealer, local to me in case something goes down after or outside of warranty.
Old Sep 6, 2013 | 11:11 PM
Originally Posted by Mani8448
@ Kozmic
Yes, we do full service and overhauls on the transmissions here, and just about anything else you could possibly need for your Evo.
Old Sep 12, 2013 | 03:04 PM
DaEvoPusha's Avatar
When I click the filedropper link from OP, it just takes me to the filedropper home page. Any way to get at that technical info on the TC-SST? I like reading info like that.
rayman0690
Jan 4, 2026 07:20 PM
richardjh
Nov 6, 2024 04:41 AM
vaqusis
56
Sep 29, 2017 08:35 AM
RogueSTi
19
Mar 14, 2009 10:26 AM
insomniac_evo
Apr 19, 2006 05:16 AM
