SST small "jump" only after a shift
Old May 31, 2014 | 03:32 AM
gsxrmel's Avatar
hello could someone tell me if this happens too? the revs have a small "jump" only after a shift at wot and if i shift after 5000 rpm, if I do it before 5000 rpm does not occur and shift perfectly
pressure is at 26 psi with a bb oem turbo conversion by owen performance and compressor is a 72 hta. if i make the shift with Less boost like 1.5 also shift perfectly in all the rpm range
the torque is about 330 lb / ft
i also have a sst table tuned and the car dont have any slip and acelerate, only a smal revs "jump" after a shift with a 26 psi boost.
is possible to fix this? or it is normaly
attach a video
http://tinypic.com/player.php?v=3h7i...8#.U4nW6nJ_uNB
regards!!!
Old May 31, 2014 | 05:59 AM
Mystykalbaby's Avatar
Can't see the video. Just load it the traditional way.
Old May 31, 2014 | 06:20 AM
gsxrmel's Avatar
link correction done thanks!!
Old Jun 5, 2014 | 10:28 AM
CFMP RAblue's Avatar
I have a similiar issue and believe the clutches are on the way out, although my issue is alot worse ie feels like driving a regular auto with mad jump. Getting jacks transmission rebuild with 500hp clutchs.
Stock turbo with ~25psi 115k kms thats over 65k miles
Old Jun 5, 2014 | 12:40 PM
gsxrmel's Avatar
is only happen if i make the shift until 4500 later 5000 .... go perfect.
regards
Old Jun 6, 2014 | 09:31 AM
it seems like its trying to soften shift shock. but i also noticed that you was kinda slack on the throttle. does it do this if your accelerating at a swift rate. not wide open but a brisk take off.
Old Jun 7, 2014 | 04:22 AM
gsxrmel's Avatar
Might explain better what you want to say? as you can see my English is not very good
thanks a lot
regards
tequila357
Feb 18, 2016 11:42 AM
aycynokia
May 10, 2011 05:33 AM
LVSBB6
Mitsubishi TC-SST Discussion
25
Feb 16, 2010 10:56 AM
boy36
Nov 4, 2007 03:46 AM
lil'evil_evo
Sep 5, 2004 12:59 PM
