SST problem: code P1836
Old Jun 25, 2018 | 10:06 PM
labwagon's Avatar
Last Friday, I got the warning (Service Transmission) in my dashboard and a check engine.
It occurred when I had just done 1 hour drive, much of it in the traffic with frequent stop. It was a sunny and hot day.
When the warning appeared, my gears were slipping, the transmission wasn't shift.
I parked my car on the side of the road and turned off the vehicle. 2 hours later, I restarted the vehicle, there was no notice (Transmission Service) but still the check-engine. I was able to roll about 2 min and shifter the 6 gears without any abnormal symptoms. I stopped the vehicle for fear of damaging my transmission even more. Using my OBD II, I picked up these 3 codes:
P1836: Shift fork 1 malfunction
P2733: Clutch / shift solenoid 1, spool stuck
P2809: Clutch / Shift switching solenoid 2, spool stuck
I have not cleared the codes or restarted the vehicle since.
The vehicle has 118,000 km (73,000 miles)
The TC-SST transmission oil change was made with OEM DiaQueen SSTF-1 oil and the OEM filter at 44,000 km (27 000 miles and 88,000 km (54 000 miles).
The car is modified:
Cold air intake, turbo back exhaust 3 "(with hi-flow cat), ECU Reflash, etc.
I have around 300 hp.
I Never have problem with the TC-SST before today. It always shift well, just slip a bit when the tranny is cold on winter or when it's very hot and in the traffic.
Never track the car but only drag race, about 10-12 races per year.
I wonder what I should do right now. Try to erase the codes, install an better oil
cooler and change the transmission fluid and filter.
Old Jun 30, 2020 | 02:30 PM
ipointatthesky's Avatar
Did you ever determined if the fluid change helped? Mine is acting similar and seems the SST fluid gets really hot and above 200F very quickly and then i have issues. I am thinking the previous shop underfilled it.
DeDMeaT
Oct 25, 2019 11:28 AM
markfromNZ
Mitsubishi TC-SST Discussion
Sep 14, 2017 12:05 PM
Masheen
17
Mar 11, 2016 08:12 PM
DjRags604
Mar 2, 2012 07:37 PM
Spunkysandoval
Jul 25, 2009 06:15 AM
