SST Almost stalls the engine when selecting Drive or Reverse
Old Oct 28, 2020 | 04:22 PM
AdamGee's Avatar
Hello guys,
recently I've changed my clutch packs, because the old ones were worn. After putting it back together, the car shifts like a glove! But there is one issue after all..
When i select Drive mode (D) or reverse (R), the RPM's quickly drop so badly and it stalls the engine sometimes. The issue occurs also if i am in Drive (D) and slowly lifting my foot off the brakes. The car will move, but it is not smooth at all.
I feel like the clutch is not disengaging properly and stays engaged a bit more than it should. My car is a 2010 Ralliart.
Some more info:
  • I did the teach-in procedure
  • OEM diaqueen has been always used
  • The issue showed up after changing my clutch packs
Thanks for any advice!
Old Apr 9, 2021 | 04:25 AM
jasonskyring's Avatar
Did you ever get this sorted? I have very similar issue but it never stalls. My idle goes to about 300-500 when coming to a stop or engaging drive or reserve. like the clutch is grapping to hard. Very similar to this...
Old Sep 1, 2022 | 11:39 AM
Maz0327's Avatar
BUMP! Anyone every figure out whats goin on here???
Old Sep 1, 2022 | 12:30 PM
AdamGee's Avatar
I've got the issue sorted, it was a bent circlip on the clutch assembly, the one that holds the pressure plate for one of the clutch packs. The problem with that was, that the circlip opened a bit and the pressure plate wasnt able to fully disengage.
Old Sep 1, 2022 | 02:19 PM
Maz0327's Avatar
How did you get that sorted? a whole rebuild? an upgrade service??
Old Sep 1, 2022 | 02:38 PM
AdamGee's Avatar
I took out the trans and replaced the circlip. But remember, the circlip was bent during the process of replacing the old clutch pack, so ti was my fault - I wasnt careful enough during the disassembly process..
TurboTylerIX
21
Dec 19, 2017 11:16 AM
TheHolyLancer
Mitsubishi TC-SST Discussion
17
Mar 17, 2016 02:41 PM
liljj2221
Driving Techniques
37
Mar 22, 2014 06:23 PM
Webman
Mar 6, 2009 03:55 PM
