I played with Vipers today...
We have two different spring styles on Nils car the fronts are single progressive "K" style DMS Barrel spring @ 650lb, and the rears are the standard 700 lb DOUBLE progresive barrel spring DMS uses. Because these springs are both barrel shaped and wound from a double tapered wire the stated rates are subjective and have no correlation to "regular or normal" springs. Sorry if this didn't help much.. My last set-up on Buddyclubs/ JIC ran about 7-800 front and 8-900 rear. but didn't have NEAR the wheel travle the DMS set-up has.
Thanks dude.. bought Hotchkis Swaybar and will install to med. setting first. Going to track this weekend - EVO virgin trip! Once I get the feel, I'll turn it up a notch. Thinking about Coilovers for next year... will research on DMS 50mms. Don't know what they are.
I'm showin your video around to friends just to let them know the EVO can kill Vipers
Originally Posted by nils
that was the advanced run group I was running with.
In both video clips I am pretty much messing around trying different lines, seeing how they work.
Got DMS 50mm's on the car with 25mm rear sway bar at stiffest setting. Cant remember spring rates right now but Robi can chime in on that.
Originally Posted by raf_EVO
thx Robi.. Good stuff. that sounds like a hard-core setup. I don't suppose the car remains much of a daily driver if you run 600~700 lbs in spring rates.
Originally Posted by feldguy
What is the sizing and offset on those wheels? Im SOLD, I love the way they look! Any feder mods? Thanks!
Yes, fender mods to run 275's...
Thanks nils. No problems with fitment, spacers, or anything? If Robi is reading or if you can ask if, Id appreciate it. I was reading weights for them and they're super freakin light!
Well they arn't that light @ 19 lbs. But they are the strongest wheel I've ever run....
Offset is +40 and they need 20mm front wheel adaptors. Enkei is currently out of stock on this wheel to the best of my Knowledge
Great stuff.
I'm saving up for my RobiSpec treatment. Those Enkei's look awesome in white. I'd love 18's, but aren't racing tires considerably more expensive in that size as opposed to 17's?
Actually, it is a 17mm spacer that works
n
since there is alot of questions about parts used on the car I put a complete mod list together...
Engine:
BR intake kit
BR upper IC pipe
BR 3" SS turbo back exhaust
BR Deluxe FMIC
BR mini battery kit
BR manual Boost Controller
BR 660 injectors
Walbro 255l Fuel pump
HKS 272 in/ex Cams
Greddy Oil Catch tank
1g BoV
PWR 'BIG' radiator
Blitz radiator Hose
ARP Headstuds
Dynoflash ECU tune (need new one)
Suspension:
DMS 50mm (Tarmac) Coil overs
Cusco Rear V Strut tower brace
Progress 25mm Rear swaybar
Robispec Lower Trailing Link Bushing
Robispec Anti BumpSteer Kit
Drivetrain:
Stock
Brakes:
Goodridge SS brake lines
Motul 600 Brake Fluid
PF 97 brake pads (front)
PF 2 piece floating rotors (front)
Custom Brake ducts (front)
Wheels:
Enkei NTO-3's - 18x9.5 w/ +40 offset
17mm custom hubcentric wheel spacers (front)
Toyo RA-1's - 275/35/18 (shaved)
Interior:
Sparco Harness Bar
Sparco 3" - 5 point harness w/ camlock (driver)
Fire extinguisher
Ioport Camera Mount
Zeitronix ZT-2 Wideband display
Greddy Oil pressure guage - 60mm w/ peak hold & warning
Greddy Oil temp. guage - 60mm w/ peak hold & warning
Greddy Water temp. guage - 60mm w/ peak hold & warning
Craig Hardy Guage Panel
Exterior:
Evodave Headlights
Evodave Tailights
C west Front Bumper
C west canards
Robispec under carriage Front Diffuser
Robispec under carriage Rear Diffuser
APR GT-200 wing w/ s2k endplates
The car still has the A/C in it and full interior. Completely driveable, fully legal if I put a high-flow cat on it... no gutted interior or flimsy carbon fiber parts... yet.
nils
Engine:
BR intake kit
BR upper IC pipe
BR Deluxe FMIC
BR mini battery kit
BR 660 injectors
HKS 272 in/ex Cams
1g BoV
PWR 'BIG' radiator
Blitz radiator Hose
ARP Headstuds
Suspension:
Drivetrain:
Stock
Brakes:
Wheels:
Interior:
Sparco Harness Bar
Fire extinguisher
Ioport Camera Mount
Exterior:
Evodave Headlights
Evodave Tailights
C west Front Bumper
C west canards
nils
Originally Posted by speedomodel
Great stuff.
thx.
Yes, the 18" size tires are alot more expensive. I am currently thinking about getting another set of 17"'s just for that reason... we'll see.
n
