What do you guys used for Suspension and Brake setup for track?
Brake:
Endless Swivel Steel Brake Lines
Performance Friction 2 Piece Front Rotors
Hawks HPS (Street)
PMU Max900 (Track)
ATE Blue
Suspension:
Stock Springs/Shocks (Ohlins Flag-L Soon...HOPEFULLY
Carbing Low Arm Bar
Hawks HPS (Street)
PMU Max900 (Track)
ATE Blue
Suspension:
Carbing Low Arm Bar
Brakes:
Centric blank rotors
Goodridge SS lines
Motul RBF600
Raybestoes ST-43
Suspension:
Stock GSR suspension set at -1.8 f -1.0 r
Cusco Lower Tie Bar Type I + II
Wheel/Tires:
5Zigen FN10R-C 17x9
Goodyear GS-CS 245/40/17
Goodridge SS lines
Motul RBF600
Raybestoes ST-43
Suspension:
Wheel/Tires:
5Zigen FN10R-C 17x9
Originally Posted by nothere
i did read some one claim removing the shield offset the caliper, if it does it is not much of an issue
Originally Posted by ovenmit331
i heard something about messing up the ABS sensor if the dust sheilds are removed...
RacingBrake front BBK (332x28 - lightest track-worthy kit out there for the Evo) and rear 2-pc rotors (coming soon), Hawk DTC60 pads, ATE Typ200 Fluid, Stoptech ss lines, dust shields removed
Ohlins R&T dampers (the new ones), camber plates, rear pillowball mounts, rear controlarm bushings, Whiteline anti-bumpsteer kit, progress rear 25mm anti-roll bar
Originally Posted by razorlab
The shield isn't even bolted to the caliper. It has nothing to do with the mounting points of the caliper.
that said, i've cut my shields back but left a small piece just to cover the abs sensor(i've heard of a couple people melting them) and since i kept that on i cut a tab off the lower mount point of the shield. sort of like a washer that i keep in just so i don't have the caliper angled(shield under top bolt but not bottom).
btw i have...
brakes:
alcon 6-pot monoblock
355mm rotors
ferodo 3000 f/r
goodridge lines
motul 600
suspension:
ohlin r/t
425/525
cusco front camber plates
works rear bar
-2.8
-1.0
5Zigen FN10R-C 18x9.5
275/35/18 ra-1's
Originally Posted by smack_evo
yes it does. the shields mount BETWEEN the caliper and the hub assembly. so yes the caliper will be off by the thickness of the shield. theoritically the pistons should just center themselves after the first time you brake and you shouldn't get any odd wear issues.
haha, for a minute i thought that the '05's might be different than my '03.
it is good to hear that you haven't had any problem with the abs cable though. because it's just more hassle to go through to keep having to put those pieces back in. i'd like to just lose them all together.
