What do you guys used for Suspension and Brake setup for track?
Old May 28, 2006 | 11:42 PM
  #31
redvolution's Avatar
Originally Posted by smack_evo
what are "the new ones"?
In October Ohlins added helper springs and re-valved the damper to handle up to 750lbs/in springs.
Old May 29, 2006 | 06:13 PM
  #32
EVIL_EV0's Avatar
I have a question.......I don't get brake fade but on hot days I do start to lose pedal.
I run ATE superblue and Carbotech XP10 pads.
Do any of you start to lose the solid pedal feel after a few hard laps?
(my front calipers are brown and yellow)
Old May 29, 2006 | 08:11 PM
  #33
RazorLab's Avatar
That's brake fade from fluid.
http://en.wikipedia.org/wiki/Brake_fade
Old May 30, 2006 | 02:44 AM
  #34
S1monLM's Avatar
I heard RRE and Vishnu never use helper springs for their ohlins. Where did you get yours from?
Old May 30, 2006 | 09:50 AM
  #35
EVIL_EV0's Avatar
Is there a better fluid than Motul 600? Or .... is my next option some kind of duct work?
Old May 30, 2006 | 09:51 AM
  #36
ovenmit331's Avatar
Castrol SRF
Old May 30, 2006 | 01:58 PM
  #37
You're confusing helper springs with tender springs. See this for clarification:
http://e30m3performance.com/tech_art...ings/index.htm
The latest Ohlins R&T for the Evo come with helper springs. The RRE and Vishnu Ohlins did not have the helper springs because they were based on the previous generation. By now they have probably moved on to the newer generation (although supply is low).
I got mine from Works in January.
Edit: The newer ones are made in Japan.
Old May 30, 2006 | 02:19 PM
  #38
leif's Avatar
suspension:
ohlins r&t (the old swedish made ones...eventually to be revalved) w/:
custom springs
tein camber plates + rear top hats
various bushings
brakes:
goodrich lines
ate super blue (i think motul is better tho)
ferrodo 2500s...to be replaced by something when my rotors go, which will be replaced by 2 piece fronts
255/17 RA1 on the standard 17x9 5zigens.
Old May 30, 2006 | 02:40 PM
  #39
Another option to duct work is a full BBK. The good ones (RacingBrake, Stoptech, Stasis/Alcon) all dissipate heat so much better than the stock parts that duct work isn't necessary for tires with less grip than Hoosiers (hoosiers might be fine too - waiting for more info).
Hagakure and I both use the RacingBrake BBK with Hawk DTC pads and haven't had any fade problems with ATE Type200/Superblue.
Old May 30, 2006 | 06:10 PM
  #40
S1monLM's Avatar
Is this the one you got from Work (stage3)?
http://www.worksevo.com/store/produc...products_id=83
Old May 30, 2006 | 06:38 PM
  #41
nj1266's Avatar
Originally Posted by razorlab
The PMU MAX900 are the best pads I have used so far in the last 1.5yrs of tracking the evo. The best thing of all is that they are cheap.
Did great in 100F+ ambient heat at buttonwillow yesterday. No brake fade or brake feel change. Until my headgasket shut down the party. 230F water temps and 280F oil temps = all my warning lights on my greddy gauges coming on. Not fun luckily I caught it before I had to tow the car 280miles home.
Two questions if you do not mind:
1. Are the pads you are using good enough for hard track driving or are they for beginners/intermediate drivers. I wanted to get some Hawk Blues for my EVO, but now I am thinking that the pad cannot handle a heavy/fast car such as the EVO. My option is to get the Hawk HT-14. Is the PMU 900 like the HT-14?
2. Why did your car overheat? Is this common for the EVO in the buttonwillow/Willow summer heat? Would an upgraded radiator (Koyo/Pwr) solve this problem?
Old May 31, 2006 | 06:30 AM
  #42
ovenmit331's Avatar
call it a hunch, but i'm guessing it has something to do with the "Until my headgasket shut down the party"
Old Jun 1, 2006 | 02:00 AM
  #43
trinydex's Avatar
mueller jics and racing brake bbk with motul and rre lines.
Old Jun 2, 2006 | 10:06 PM
  #44
Yes, although I have changed the spring rates. Probably going to change again soon.
Old Jun 2, 2006 | 10:08 PM
  #45
I recommend the Hawk DTC60 or DTC70 over the Blue or HT-14. Higher MOT, better pedal feel, and easier-to-remove dust.
