Track whores with MRs?
Old Sep 11, 2007 | 06:41 AM
  #481
555R's Avatar
please post the specs for the cooler parts list
Im interested primarily for time trial use and HPDE on my MR
Old Sep 11, 2007 | 06:21 PM
  #482
Wheelhaus's Avatar
razorlab, you're a 5sp sellout. jk..
I'd also love to see specs, I'm in it for the same reasons as others (HDPE, time trials, random track days, etc).
Old Sep 11, 2007 | 06:29 PM
  #483
voidhawk's Avatar
Have any of you seen this kit by HKS? My japanese is pretty poor, but from the location in the photo it looks like a tranny cooler setup (or easily adapted to be one).
Old Sep 11, 2007 | 07:47 PM
  #484
BlackTrack's Avatar
^^^ Awesome find, more info would be great!
Old Sep 12, 2007 | 10:46 PM
  #485
voidhawk's Avatar
don't have a whole lot more info about it ... the article is from a japanese "LancerEVO" magazine (vol 25). I've also seen adds for it in a couple of Hyperrev magazines, but nothing stateside yet.
Old Sep 13, 2007 | 11:22 AM
  #486
timmiii's Avatar
Has anyone ever thought of making a 4th, 5th, and 6th gear straight cut gears which would replace the stock helical gears? I'm sure this could solve the problem of breaking teeth and would be much cheaper than doing an entire conversion from 6 to 5 or overhauling the whole 6 speed with a cooling device.
If the WRX 5 speed and STi 6 speed guys have this option why cant the evo guys have the same option?
Old Sep 13, 2007 | 11:41 AM
  #487
4cdndctn's Avatar
Even easier/ less expensive would be to cryo the full transmission - I'm considering this as a winter project.
Old Sep 13, 2007 | 11:46 AM
  #488
4cdndctn's Avatar
The kit above may be a shot from the twin cooler kit offered by HKS or Greddy? It looks familiar...
Old Sep 13, 2007 | 02:38 PM
  #489
DaWorstPlaya's Avatar
Straight cut gears and cyro-treating the gears won't do much for durability. Straight cut gears just end up being noisier than their helical counterparts and may even reduce the durability of a gear as now there is less surface area for the force to act on which also increases the pressure a tooth has to bear.
Cryo-treating and heavy shot peening "may" only increase the strength of the gears by approximately 10%. Longevity of the 6 speed will depend on the torque one is generating, the shock it is subjected to (clutch engagement) less shock = longer life, the "correct" type of lubrication. I would assume wider gears and bigger (deeper/wider) teeth are the only way to improve the durability of the 6 speed to with stand more power.
Keep your power expectation low and you won't have problems.
Old Sep 14, 2007 | 08:14 PM
  #490
timmiii's Avatar
Straight-cut gears have been known to handle high amounts of torque. Many racecars use straight-cut gears so thats at least some evidence of them being able to handle the abuse power.
If you think about it the teeth in a straight cut gear is stronger because the teeth are straight versus curved. Since the teeth are curved in helical designs, they tend to handle torque for less amount of time versus a straight-cut gear. This is based off the idea that the helical gear has curved teeth and if you actually try performing a stress test analysis on the two gears with the same width, length and material teeth (one being helical the other being straight-cut). You will find that stress levels will be reached in many more spots in the helical design, quicker, than the straight-cut design. Hence the helical gear design is weaker than the straight-cut gear design.
I can't say much for noise, but some people might actually like it.
Old Sep 15, 2007 | 09:21 AM
  #491
marksae's Avatar
Hey guys, I need your help collecting data from you 6-spd guys that track your cars, failure or not. This is for a school project and would probably serve the evo community very well too. If you could reply to this thread, I'd really appreciate it!
https://www.evolutionm.net/forums/sh...d.php?t=295632
TIA!
Old Sep 21, 2007 | 09:41 AM
  #492
oneguy's Avatar
i think that is the HKS dual oil cooler. Below is a pic of the oil cooler kit.
Old Sep 21, 2007 | 10:26 AM
  #493
Wheelhaus's Avatar
I recently did a full fluid change, engine, tranny, tc, rear diff... The OEM fluids STINK!
Anyways, I used 1qt of Shockproof Heavy and approx 1.5 qt MT-90 (used as much as necessary to overflow the fill hole). I'm surprised how well it shifts, it already feels smoother than OEM. Seems like a nice blend, hopefully the qt of SP Heavy will add a significant level of protection for those dainty little gears...
As for the oil pumps and radiators, are they rated for a maximum viscosity? I wonder if the uberthick shockproof would be too much and cause the pump to burn up...
Old Sep 21, 2007 | 10:30 AM
  #494
Did you test to see if the different fluids mix? Or you may have 2 different oils that don't mix and seperate in layers in your tranny (kinda like oil and water) ...
Old Sep 21, 2007 | 10:37 AM
  #495
boostedwrx's Avatar
I still think the oem fluids are the best. I read somewhere the oem 75w85 is a syn oil anyway.
