Track whores with MRs?
Old Dec 30, 2006 | 07:30 AM
  #421
mrfred's Avatar
Originally Posted by 555R
even if outside diameters are the same?
4th gear on the 6spd is 1.100:1, so the tooth ratios would have to be 11:10, or 22:20, or 33:30, or 44:40, etc. Below is a pic of razorlab's broken 4th gear set. When I count the teeth, I get 33:30. If there is a revised 4th gear for the '06 MR, and it has more teeth, then its going to be 44:40, so it will have 11 more teeth on one gear and 10 more on the other while maintaining the same gear diameter (shaft spacing couldn't not have changed). Adding that many more teeth would make the teeth much thinner, and would not make the gears stronger.
At any rate, one possible way to finish this debate is to call a parts counter and get the part number for 4th gear on the input shaft for an '05 MR and an '06 MR. These part numbers are readily available, and if they are the same part number, then the 4th gear sets have to be the same because if one gear in a set is not changed, then the other is also not significantly changed.
Old Dec 31, 2006 | 12:01 AM
  #422
sblvro's Avatar
Originally Posted by mrfred
.... one possible way to finish this debate is to call a parts counter and get the part number for 4th gear on the input shaft for an '05 MR and an '06 MR. These part numbers are readily available, and if they are the same part number, then the 4th gear sets have to be the same because if one gear in a set is not changed, then the other is also not significantly changed....
I just did that.
Old Dec 31, 2006 | 08:14 AM
  #423
mrfred's Avatar
Originally Posted by sblvro
I just did that.
You did it for the output shaft where the part numbers are not available. I'm saying that it should be done for the input shaft where the part numbers are readily available.
Old Jan 1, 2007 | 04:31 AM
  #424
WarmPepsi's Avatar
Since this is a thread on MR's...
Whats the max number of days on a stock MR tranny? (05) I think i may be the highest total with 26 so far. hahah
Old Jan 1, 2007 | 09:12 AM
  #425
Warrtalon's Avatar
WarmPepsi, anyone could go 26 or even 260 days driving as slow as you!!! j/k
Old Jan 1, 2007 | 10:30 AM
  #426
Wheelhaus's Avatar
zing!
I'm still wondering if anyone has found any substantial differences between the VIII MR and IX MR 4th gear.
Old Jan 1, 2007 | 10:37 AM
  #427
voidhawk's Avatar
just to put that into perspective:
1) what is your whp / wt ?
2) what fluid do you use ?
3) how often do you change it?
thanks
Old Jan 1, 2007 | 02:32 PM
  #428
WarmPepsi's Avatar
me + full fuel is 3500. I run 18-19 psi on track, roughly 280 whp (300 @ 21 psi then backed off boost + timing).
Use stock fluid.
Changed it after 12 events. About to change it now after 26.
Average track miles for an event is roughly 160-180. I'm that guy thats out throwing the car around for the last 15-20 minutes when everyone else is packed up. Just getting more laps, more laps, more laps.
Old Jan 1, 2007 | 02:35 PM
  #429
WarmPepsi's Avatar
Haha, sunday was day #1 as an instructor.
So the boss of the club i run with was giving me a hard time, as i was harrassing the Panoz race cars (for the 2-3 laps while they were trying to get the slicks hot).
Then they got them warmed up and it was see ya later, but for those first 3-4 laps, man it's fun, because they're trying to get away, like "damn, why is this evo in my mirror". One guy even completely blew the braking on the hairpin while in front of me All in good fun though. I think it's honestly fair to say that i drive the wheels off my car. I honestly think that a better driver could run a 1/2 second faster in my car, but not a full second. (at least around my local places).
Old Jan 1, 2007 | 04:09 PM
  #430
RazorLab's Avatar
18-19psi probably isn't making much torque, which is what we really should be looking at here.
My car makes 318whp/314wtq now on a mustang that reads like buschurs, aka low.
Let's see how long 6spd #2 lasts.
Old Jan 1, 2007 | 04:17 PM
  #431
WarmPepsi's Avatar
well, i can only say im sure the mustang i was on read low. I'll have to dynojet it here soon for nasa purposes, and it'll be set for 315 or so. (have to stay under 322 for my base class)
Old Jan 2, 2007 | 10:01 AM
  #432
DaWorstPlaya's Avatar
Originally Posted by nolimits079
Everyone - I was thinking... The UK FQ-400 and FQ-360 use a six speed transmission. I'm certain that people are road racing these cars. With the additional torque, it seems almost certain to me that they would be busting their transmissions quicker than us.
Remember you can make a lot of HP with very little torque, it just needs to be made at higher RPMs. Sheer torque is what breaks gears, ofcourse the higher the RPM the more the heat due to friction. This is where cooling and type of gear oil comes into play. The FQ 400 series uses HP rating to classify them selves.
Does anyone know which company is responsible for designing the modifications for these cars in the UK? Maybe we can get specs on their transmissions and gain some insight.
I believe it is done by Ralliart UK.
Old Jan 2, 2007 | 11:48 AM
  #433
meanmud's Avatar
no - it's a new name:
http://www.xtreme-uk.net/
Old Jan 2, 2007 | 12:46 PM
  #434
Not according to these guys: (3rd paragraph down)
http://www.evo.co.uk/carreviews/evoc..._mr_fq400.html
Old Jan 2, 2007 | 02:07 PM
  #435
SRT-TO-EVO's Avatar
Has anyone dug up info on the IXmr 4th gear, vs VIIImr 4th gear yet?
