Track whores with MRs?
Old Nov 18, 2006 | 12:12 AM
  #376
RazorLab's Avatar
Originally Posted by razorlab
We'll see how my temps are at thunderhill this friday.
Well today was a big eye opener.
Today at Thunderhill was about 62-65F ambient. Pretty cool track all day.
I was instructing today so I only got about 65 on track miles. The first couple sessions I did I wasn't pushing the car as hard as I usually do since this was my first track event in about 5 months. Trans temp hit 194F to 203F.
The last session I had in the day was at 4pm and the track was cold and slippery. I was pushing the car pretty hard playing lead and follow with a evo track buddy of mine. After 3 laps the trans temp raised to 221F. This is when I came in and called it a day.
This really makes me wonder what kind of temps the trans was doing in the 90-95F summer events.
The trans cooler is going on ASAP.
Old Nov 18, 2006 | 10:11 PM
  #377
voidhawk's Avatar
that's pretty hot all right ... where did you measure, on the housing or in the fluid?
Old Nov 19, 2006 | 05:26 PM
  #378
Wheelhaus's Avatar
with temps like that where the sensor is located, you're guaranteed to have much higher tooth face temps, how much exactly is anyone's guess.
Do let us know how it performs with the cooler.. When do you forsee being able to do some hot laps with it installed?
Old Nov 19, 2006 | 06:10 PM
  #379
RazorLab's Avatar
Here is the parts listing for my trans cooler setup, all part #'s and prices are from Summit Racing, YMMV:
1. Fluidyne Fluid cooler - #FLD-DB-30110 - 4x11x2 - $94.39
2. Tilton Transmission/Differential Oil Cooler Pump - #TIL-40-524 - $178.39
3. Aeroquip Socketless Hose End / straight / -8AN barb - #AER-FBM1513 - $5.95
4. Aeroquip Socketless Hose End / straight / -10AN barb - #AER-FBM1514 - $6.95 x 2
5. Aeroquip Socketless Hose End / 45degree / -8AN barb - #AER-FBM1523 - $16.95 x 2
6. Aeroquip Socketless Hose End / 90degree / -8AN barb - #AER-FBM1533 - $16.95 x 3
7. Aeroquip Socketless Hose End / 90degree / -10AN barb - #AER-FBM1534 - $18.95
8. Aeroquip AN to NPT Adapter Fitting / straight / -8AN Male to 3/8in NPT Male - #AER-FBM2007 $3.95 x 2
9. Aeroquip Socketless Fitting, Union Reducer, Male -10 AN to Male -8 AN / straight - #AER-FBM2163 - $10.50
10. Aeroquip Hose Mounting Clamps, Cushioned, .750 in., Set of 5. / #AER-FBM3486 - $3.69
11. Aeroquip Hose, AQP Socketless, Rubber, Black, -8 AN, 15 ft. Length / #AER-FCN0815 - $48.88
12. Aeroquip Hose, AQP Socketless , Rubber , black , - 10 AN , 10 ft . Length / #AER-FCV1010 - $37.95
Total : $505.25
This is not the final listing as some fittings probably won't be used. I also need to fabricate a bracket for the pump and the cooler itself.
Old Nov 19, 2006 | 06:16 PM
  #380
Sharkbite2000's Avatar
I would love to see the results.
Old Nov 29, 2006 | 08:39 PM
  #381
nukblazi's Avatar
about a year ago I mentioned that I bought the RS for the 5-speed and got some interesting comments back. The 6-speed in my old MB C230 went a couple times... trans temp, broken gears... the 5-speed is still holding up well in my Evo... though, it DOES NOT disengage properly at times and I expect I will break a gear eventually... my guess is 2nd... fresh fluid seems to be the key... I change mine with every oil change or, every 3k miles AND after every track event ... helps a lot in regards to smoothness...
Hope everyone is well,
Thomas
Old Nov 29, 2006 | 09:52 PM
  #382
voidhawk's Avatar
my 6sp has started to act up again too in a similiar fashion - it doesn't like to get out of gear sometimes. It will even make a kind of humming noise when I try to move the shifter, which goes away a second later when it finally lets me move. Anybody have any insight to why this happens? It's never done this before ...
Old Nov 29, 2006 | 10:25 PM
  #383
marksae's Avatar
Thomas
What you experienced on your other car is totally irrelevant. It's a totally different car w/ a totally different tranny. Almost all variables are different. Different power, drivetrain, etc..
I think there are enough examples of tracked 5-spd evos out there to conclude that the 5-spd can take the repeated abuse.
Old Nov 30, 2006 | 12:19 PM
  #384
QuickOne's Avatar
razorlab,
Do you have any pics of your oil pickup/return in the tranny? I need to install a cooler in my MR and wanted to find out where you got the connections from
Thanks..
Old Nov 30, 2006 | 06:07 PM
  #385
RazorLab's Avatar
If you dont have the transmission off the car with the casing off, you will have to use the drain and fill plugs for hooking up the tranny cooler.
Old Dec 1, 2006 | 02:37 AM
  #386
WarmPepsi's Avatar
Any chance you know the thread side/pitch on the drain plug?
Old Dec 1, 2006 | 06:22 AM
  #387
QuickOne's Avatar
Damn. I was hoping not to have to build a "T" system to get the fill plug to work properly. Plus i want to hook up a temp gauge. Guess i don't have much of a choice..
So, as WarmPepsi said, do you happen to know the detailed on the plug's thread pitch and what not?
Old Dec 8, 2006 | 10:29 AM
  #388
555R's Avatar
any updates on the gearbox issue
Old Dec 16, 2006 | 09:55 AM
  #389
VR4orceCJ's Avatar
Cool
For the 5-speed you need one 16 x 1.5mm and one 18.5 x 1.5mm for the 6 speed you need two 18.5x 1.5mm
You can find them at:
http://www.pegasusautoracing.com/adv...PLUMADAPMETRIC
You can select the size that fits the other fittings you are buying. I'm sure you can source them locally or at Summit etc as well.
Old Dec 26, 2006 | 09:23 PM
  #390
nolimits079's Avatar
Razorlab - I'd love to hear what your temps are for your next track event. A transmission cooler sounds very tempting now.
Everyone - I was thinking... The UK FQ-400 and FQ-360 use a six speed transmission. I'm certain that people are road racing these cars. With the additional torque, it seems almost certain to me that they would be busting their transmissions quicker than us.
Does anyone know which company is responsible for designing the modifications for these cars in the UK? Maybe we can get specs on their transmissions and gain some insight.
Is there an Evolution forum specifically for the UK?
