Race Pads, what does everyone recommend?
Originally Posted by Dustin@Vishnu
Ten track days!? I get like 2 or 3 out of a set of pads, no matter what pads they are.
Anyway, how are the DS3000s?
Originally Posted by I'mStock
Question for all the PF97 users.
I know these pads are carbon metallic, but are they supposed to throw an INSANE amount of sparks when warmed up? When I'm driving at night and do a couple hard stops I get visual sparks off of them. I think it looks cool, but Jesus, it it normal?
PF97 front pads, stock rotors.
That's interesting news. I'll inform the guys around here that have set some class records at MSR with those pads over 1000's of total laps. EDIT: both with Evos...
Originally Posted by razorlab
Hawk blues pretty much suck on evos.
On evos? Didn't work for me.
Sorry...yes, on Evos, edited. These were used with a few different rotor combinations, though. They were very hard on most rotor choices these guys used like the PF or StopTech. They eventually decided to go easier on the rotors and went with other pads like 97's, or DS3000. One guy is now running a Brake Man BBK with their pads...not sure what the other is running these days.
The PF pads from RRE had decent initial bite, were very easy to modulate (not so on/off), but couldn't stand up to aggressive braking w/o some fade.
The Project Mu level max 900 pads have significantly better inital bite and also handled the heat better. My last set did look pretty bad (surface cracking/crumbling) after my last track day and some "wait until you see God" braking.
Next up will be the Carbotech XP12's.
Johannes
Johannes
I had BAD pad transfer problems with the DS3000's. Other than that they were great. I ran PFC-01's last weekend and they performed very well, but I boiled the fluid in every session...
The 3000s arent bad. They bite really hard, and fight against fade pretty well. Then again, the 2500s don't fade if you are driving the car right, but you do loose a little bite. I have a set of Hawk HPs on the rear of my car right now. My god those things dust like crazy, and it is extremely hard to get off the wheels.
Bad wheel shake under braking. 3 events and I had the same problem at each one. The only thing that helped was changing to a different pad. I never had any transfer problems when I ran 2500's, but they aren't enough pad for the way I drive. I would probably kill a set in weekend now.
FS[SouthEast]: Brake Pad set, front and rear, great shape
hutch959
Jun 18, 2017 05:18 PM
Evo D
Jul 11, 2010 07:45 PM
