Building a reliable DD track car
Old May 31, 2007 | 01:08 PM
  #61
RazorLab's Avatar
Originally Posted by boostinpsi
who built your transmission razor? im getting some grinding going into 1st and my tcase is starting to whine :/
where do you exaclty install a tranny cooler? does it help a whole lot? i have always wondered.
TRE rebuilt. Cooler isn't installed yet because of reasons I posted above.
Old May 31, 2007 | 03:26 PM
  #62
dsycks's Avatar
Of course, the last piece in the puzzle is to drive the car with some mechanical sympathy. Driving hard on the track doesn't mean beating the living **** out of the car. Nor does being gentle on the car mean driving like your grandma. You can be very, very fast around a track while still being gentle on the car.
Agree! This line of thought served me well with my last car and so far so good on my Evo. My hope is to be as fast as possible while being as smooth as I can be. I may beat out a few 1/10ths by being more aggressive but my biggest gains are without question is other areas where I need to improve.
As such I hope to keep my car strong and healthy so it can get me as much seat time as possible.
Old May 31, 2007 | 05:18 PM
  #63
Kayaalp's Avatar
Originally Posted by texrex2002
No comments yet on the NOS MMT octane booster for knock protection.
It's basically useless. It raises your octane by one "point." In other words, you'll go from 93 octane to 93.1 octane. Nothing to write home about.
just btw we have good 93 oct here is TX, so it is in addition to that.
Since you're running stock engine management (no tune) and stock boost controller (19 psi peak with high-rpm boost taper) you'll be fine. Remember the stock fuel maps and boost profile are tuned for 91 octane...otherwise Mitsu wouldn't have been able to sell the car in The People's Republik of Kalifornia. If you run 93 octane, you're already way above the level where you'll run into knocking.
Emre
Old May 31, 2007 | 05:30 PM
  #64
Warrtalon's Avatar
Not to mention the stock tune dips into the 9s for AFRs. Last thing you should be worried about on a stock boost / stock tune Evo is detonation, imo. I'd be more worried about EGT than anything.
Old May 31, 2007 | 08:07 PM
  #65
Stop&TurnFreak's Avatar
Wide band, if th eengine is dropping in the 9's should you be worried about being too rich?
Old May 31, 2007 | 09:08 PM
  #66
stimpy's Avatar
I was just looking at the stock dyno runs on my car. The damn thing was going to about 9.8:1 AFR. The car wasn't very happy with the timing or fuel. I never ran it with the stock tune, but I've put on quite a few miles with revised fueling (a sensible number richening up to about 11:1) and a bit less timing for our crappy 91 octane.
If I can ever get a downpipe to stay on my car (shop development vehicle), then I could get some bungs in place and see what the car does under the harsh conditions at the track.
-Jon
Old Jun 1, 2007 | 06:33 AM
  #67
texrex2002's Avatar
Interesting. I used to run 27PSI with it on my subaru, with no knock, while without it I would get the occasional ping without it at 22-23psi.
I agree that most fuel additive is useless and raise octane by like 0.1. Ive had good results with Torco and NOS brand (the two that contain MMT). one odd side effect is that it turns your plugs orange...
not contradicting or anything, just sharing my anecdotal evidence.
Old Jun 1, 2007 | 06:36 AM
  #68
texrex2002's Avatar
so people with the taper removed (yet still on stock boost control hardware) have more to worry about?
Old Jun 1, 2007 | 07:16 AM
  #69
Kayaalp's Avatar
Even if a 12oz. bottle of NOS Octane Booster contains MMT, it's a very small dose. Will such a small amount of MMT make a difference? Wth the Torco stuff, have to add a significant volume to your tank. I wonder if a small bottle of NOS will make much difference considering how small the dose it.
According to the NOS ad copy, one 12oz. bottle "increases octane effect as much as 3 points." So that will take you from 93 to "as much as" 93.3 ... which means it'll probably be a bit less than that (otherwise they wouldn't have said "as much as"). Again, it's not such a dramatic effect unless you add lots of it.
EDITED TO ADD: I've just noticed that NOS offers a "Racing Formula," which they claim increases your octane by "as much as 7 points." I guess that's the one you guys were referring to. A 5-7 point increase actually might be significant. I stand corrected
Emre
Old Jun 1, 2007 | 07:20 AM
  #70
Kayaalp's Avatar
Sure. As the engine runs at high rpm, it runs hotter and is more prone to knocking. It's safer to richen the mixture at higher rpms to help solve both problems. Adding more air at high rpms without increasing fuel delivery may lead to a lean running condition, which is quite dangerous for a turbo engine running the sustained high revs you see on the track.
Stock engine management is on the rich side to start with. The rich fueling plus the stock boost taper keeps the engine running relatively cool and has very little tendency to knock. As you'd expect, the OEM "tune" trades performance for engine longevity. Simply turning up the boost (without addressing fueling) is a cheap way to make more power, but you cut deeply into your safety margin.
Emre
Old Jun 1, 2007 | 09:51 AM
  #71
Warrtalon's Avatar
Who has such a thing? I've never seen a MAP sensor log showing anyone with no taper on the stock BCS especially without a flash. Are you saying you have stock boost and 0 taper?
Old Jun 1, 2007 | 09:24 PM
  #72
texrex2002's Avatar
Emre
This is actually the text I read before I started using it:
NOS® Octane Booster Racing Formula
NOS performance for the serious enthusiast. Developed to increase octane effect up to 60 points or 6 full octane numbers. Blended with MMT and our performance-enhancing Powertane, along with Nitro Methane and unique lubricants specially developed for high performance engines.
could still be just marketing bull...
Old Jun 1, 2007 | 10:45 PM
  #73
dsycks's Avatar
6 full numbers huh... I wonder how much you have to toss in to get that?
Old Jun 2, 2007 | 01:30 PM
  #74
texrex2002's Avatar
I think it's a 12 or 16 oz bottle, and treats up to 16 gals
we have 14 gal tanks, so not sure how that works out.
Old Jun 2, 2007 | 07:49 PM
  #75
djh's Avatar
djh
MMT is used in several countries, Canada being one -- though there's a move to ban it, for octane trimming at the refinery. There's a standard formula used to estimate the octane increase with MMT. MMT very quickly hits a point of diminishing returns and also has less of an effect when you start with higher octane gas. Off the top of my head, trying to remember the formula, I don't think you're likely to get better than 95 AKI no matter how much you use.
Dave
WarmMilk
942
Sep 14, 2017 08:55 AM
Pure EvoIX
Apr 21, 2013 04:40 PM
Duo Maxwell
For Sale - Cars For Sale
Mar 29, 2013 09:13 AM
Insidious Evo
13
Apr 11, 2010 12:24 PM
CBRD
Sep 27, 2009 04:57 PM
