Rear Bump Steer Correction Kit
Old Dec 30, 2015 | 07:15 AM
  #61
amn_suazo's Avatar
Originally Posted by dsm nexus
I installed the same bushings and mine was also a bit more prone to negative toe. You can rotate the ovals out a tiny bit to help. -.7 rear total toe is not bad at all. It will help keep the rear a bit more stable. I ran a small amount of negative toe in the rear and positive in the front.
I might have wrote that wrong. I'm now prone to toe out. Edited original post to add my issue is toe out in the rear.
Old Dec 30, 2015 | 07:23 AM
  #62
dsm nexus's Avatar
Toe out in the rear is a major no no unless you like the back end to come around front. Might be able to get some of it taken care of with rotating the ovals inwards a bit. Whats your height from the front and rear of the bottom and most outside edges of the sideskirts?
Old Dec 30, 2015 | 02:43 PM
  #63
amn_suazo's Avatar
EXACTLY! Need to get my Toe to Zero without adding more than a half degree of camber. In the front I'm about 10 1/2in height wise from the ground and about 11in in the rear.
Old Dec 30, 2015 | 02:56 PM
  #64
dsm nexus's Avatar
Is this measuring center hub to fender?
Old Dec 30, 2015 | 07:07 PM
  #65
amn_suazo's Avatar
Measured from the top of the side skirts on inner fender
Old Dec 30, 2015 | 07:29 PM
  #66
LetsGetThisDone's Avatar
Measure from the bottom so we know your ride height. The bump steer kit is designed for lowered cars. So it may not work properly if the car isn't low enough.
Old Dec 30, 2015 | 08:13 PM
  #67
amn_suazo's Avatar
About 6 1/4in front and 6 3/4 rear
Old Dec 31, 2015 | 08:12 AM
  #68
EVOizmm's Avatar
Almost a 2 year bump here. Bushings installed today as well with some trailing arm bushings. My alignment before for the rear was -1.3 camber and 0 toe. I'm on FA500 coils at an ideal ride height. Again everything was installed correctly. At the alignment shop and trying to Zero out the toe and can only max it out with -.7x of toe(Toe Out). Anyone have any suggestions of why this is happening or what I can do to fix it? As of now we raised the camber to -2.1 to get the toe to 0. I would like to get my camber back to -1.3-1.5 WITHOUT raising the ride height.
More than likely, the bushing (Bump steer offset hole) is not rotated correctly. seen this issue before.
Old Dec 31, 2015 | 09:44 AM
  #69
He was texting me about it that other day, says its offset straight down per the instructions.
Old Jan 2, 2016 | 08:43 AM
  #70
amn_suazo's Avatar
Was thinking about "clocking" the bushing about 45 degrees to change the angle enough to get the Toe back to zero with the amount of camber I want. Any reason to not do this?
Old Jan 4, 2016 | 06:16 AM
  #71
dsm nexus's Avatar
I would start around 20-25* and if its not enough, then incrementally increase a tiny amount.
Old Jan 4, 2016 | 09:24 AM
  #72
03whitegsr's Avatar
Sounds like the car is too raked out for "ideal" ride height? At least from a performance perspective. The car should be basically level front to rear (which means the back will look lower relative to the fender opening) to put the suspension in more optimal geometry.
Also, depending on the rest of the setup, 2 degrees of camber in the rear is about right.
Old Jan 6, 2016 | 11:13 PM
  #73
amn_suazo's Avatar
[QUOTE=03whitegsr;11558325]Sounds like the car is too raked out for "ideal" ride height? At least from a performance perspective. The car should be basically level front to rear (which means the back will look lower relative to the fender opening) to put the suspension in more optimal geometry.
Dropped the rear to level out the car. Went back to the alignment shop and was able to get thepassenger side camber down to 1.7 and Zero Toe. Not where I want but almost half a degree closer than before. The driver side however didn't change. Measured the height a few times to make sure the height was correct on both sides. LCA bushings are whiteline with 10k miles on them. this leaves my young self scratching my head
Old Jan 12, 2016 | 12:48 PM
  #74
amn_suazo's Avatar
PROBLEM SOLVED! Since the toe arm was installed with the car on the lift, the bushings never settled. Just loosened the arm on both sides while the suspension settled and problem fixed!
Nast_Nas
Outlander Sport
19
Sep 24, 2019 03:34 PM
fusionofideas
For Sale - Cars For Sale
Mar 10, 2016 08:29 PM
J!n K@z@mA
19
Mar 8, 2016 11:34 AM
sikwititevo9
14
Mar 1, 2016 07:13 PM
sikwititevo9
For Sale - Miscellaneous Automotive
11
Mar 1, 2016 07:12 PM
