NASA TTB or TTA?
Old Mar 2, 2009 | 09:40 PM
  #61
smack_evo's Avatar
^^^ yeah but now there is no hit for stock ecu flashing. that used to be 10 points alone
Old Mar 3, 2009 | 06:32 AM
  #62
Loser's Avatar
That's a nice bonus.
Old Mar 3, 2009 | 07:20 AM
  #63
Fireball's Avatar
I gave up trying to squeeze into TTA, especially since last year it was ruled in my area by C5 Z06's, and given that one of the main tracks was Road America, I didn't stand too much of a chance.
I just couldn't keep up in the top end, but I'd always catch them in the turns.
I think I'm aiming for TTS now, which was even slower than the TTA vettes last year.
Although I'm trying to aim for 2010 to run a bunch of the TT events and try and win some! The rules may all change again. It's difficult to understand now even!
Old Mar 3, 2009 | 10:26 AM
  #64
boomn29's Avatar
Originally Posted by Loser
So we really have only 14 points to play with before we get bumped up to TTA right?
Yep and yep. If you were taking 10pts for an ECU flash - then you basically get 5pts back to play with. If you weren't; then they're assuming you were or will and charging ya a 5pts Turbo premium.
I'm using those points to slide down into TTB personally. It's as much a cost competitive move as any. TTA/S is just expensive - on consumables such as gas/tires - as much as anything.
Whatever you pick - MAXIMIZE your class.
Old Mar 3, 2009 | 12:18 PM
  #65
Loser's Avatar
Hopefully there's an upgrade path that takes an optimally modified TTB Evo to an optimally modified TTA Evo without having to discard too many of the parts.
Old Mar 4, 2009 | 10:38 AM
  #66
MSP608's Avatar
This looks like a fun discussion, think I'll join in. The ECU thing was a pleasant surprise. I'll be in TTB with a couple points to spare with an STi, but 225 R888's.
Old Mar 4, 2009 | 10:46 AM
  #67
smack_evo's Avatar
if you have a couple points left, do what ever you can to get to a 10 point tire. coming from the 888's you're only 3 away. there is no better points/laptime ratio than tires.
just think about every mod as laptime and it will make your decisions much easier.
888's to hoosier/hankooks are worth at least 2 seconds on a 2 minute lap. there is no other 3 point items to gain that much time out there. you could maybe make an argument for bumping up to the next level of suspension but then you still need proper tires to get the time out of them.
perfect example for a waste of points is taking a 6 point hit on an evo ix for cams. the 20-30whp you gain is not going to give you a return in time as throwing those 6 points into tires. not even close.
also remember that if you're serious about this stuff then you really only need a lap or two to get your quick time in so going down a size but up in grip still pays off. obviously your tires will go away faster since they won't be able to handle the heat as well and will give up sooner. but that doesn't matter in time trials.
Old Mar 4, 2009 | 11:29 AM
  #68
MSP608's Avatar
I'm not that serious about it yet since I'm still doing HPDE's haha. I'm aiming to have have my TT license by the Grassroots Motorsports UTCC in July at VIR. After that I'll hopefully be doing TT at NASA MA events.
Old Mar 4, 2009 | 02:18 PM
  #69
boomn29's Avatar
Not really.
The first set of mods - to cover the 14 (+5 for turbo = 19) for the base class of an VIII/IX are fairly simple. You have a few choices to make, but everyone's probably going to do suspension and tires.
To jump up to A; you get another 19 points to play with. Bigger tires are probably in order - and you've got to add more power to keep up with the Vette's. I'd be thinking aero mods as well.
Hopefully I've helped out some without being too vague. I've got a ton of spreadsheet ideas I've worked up for B and A - I suggest trying the same. Download the spreadsheet from NASA that automatically counts points and it's easier to work with. When you first start adding up; tire sizes are confusing to figure.
Old Mar 4, 2009 | 02:24 PM
  #70
Loser's Avatar
Originally Posted by boomn29
Not really.
That makes sense. What I meant was that I hope I won't have to discard mods I make to achieve a TTB when I decide to move to TTA.
Old Mar 4, 2009 | 07:07 PM
  #71
MSP608's Avatar
Not really.
Where is this? I saw a point calculator or something but it said that it was temporarily down.
Old Mar 5, 2009 | 06:54 AM
  #72
boomn29's Avatar
Weird; I found it in the forums. It may have been one someone else updated personally. Either way; PM me your email address and I'll send it to you.
It's nice in that you check your mods and it figures up all your points for you. Another tab figure your power/weight ratio as well.
Old Mar 5, 2009 | 06:56 AM
  #73
boomn29's Avatar
I'd doubt it. You might decide to upgrade certain things - which is kinda re-modding.
For instance getting a different set (wider) of tires/rims since you have more points in A. Or going with a fancier suspension setup (piggybacks, or > $3k MSRP) since you have more points.
Old Mar 28, 2009 | 12:41 PM
  #74
EVOlutionary's Avatar
I guess I'm screwed. I have 91 points, plus a modified turbo. . . Off to TTR once I get through the HPDE levels . . .
Nothing like jumping head first into the deep end before checking to see if there's water in the pool!
Old Mar 29, 2009 | 09:04 AM
  #75
Loser's Avatar
This should be legal without incurring any points right?
https://www.evolutionm.net/forums/ev...available.html
