Which Big Brake Kit for Road Racing??
Old Oct 26, 2008 | 10:13 AM
  #61
chronohunter's Avatar
Originally Posted by jid2@[BINARY]
^^^^^ like you know anything about braking . Look at yourself in this picture. Those used to be nice pretty brakes .
Thanks, just to prove the point, those are still on my car! Also the set-up on Smogrunner's EVO which finished a strong 3rd (tied with the Cobb R35) in this years USCC. Nice comments about the brakes in the article ("simple yet effective"). With some new 888's and a different driver that car could/should have won the road course. It had gone close to the winning time before with a stock turbo (-120whp) and untuned Ohlins (I know excuses, excuses )
Old Oct 26, 2008 | 01:20 PM
  #62
theshadow's Avatar
Lasting 30 minutes on a stock based setup is pretty impessive actually. No fade at all?
Peeps looking for proper racing Evos to model road race worthy brake setups after need look no farther than Super Taikyu - time trials are a whole different ballgame than road racing when it comes to brakes. You could probably do OK in time trials using stock rotors and AutoX pads
Old Oct 26, 2008 | 02:47 PM
  #63
RaNGVR-4's Avatar
Ive always loved that picture at secondcreek^, that track was nasty on brakes
Originally Posted by AlwaysinBoost
care to elaborate on your technique?
Paul always says it better than I can:
Originally Posted by chronohunter
... pop on the pedal pretty darn (shockingly for the uninitiated) hard without immediately tripping the ABS (that is too hard). Then maintain that level until turn in where you bleed off (at a rate that keeps the car pointing, turning efficiently... as you might surmise that varies with the car and corner).
Thats how Ive always understood braking technique
slowly applying more and more pressure is what builds up heat. youre on the brakes longer, and theres already lots of heat in the brakes when you reach 100% braking, its really adds up.
Hopping on them hard and, as paul says, "bleeding" off of them also helps keep the car settled as you enter the corner, as I understand it. jumping off the brakes when entering a turn shifts the weight too much.
But Im not a driving guru, so listen to paul
Old Oct 26, 2008 | 04:30 PM
  #64
exactly, you got it, it's not so much "settled" as "balanced" and efficiently turning
as for theshadow 30 minutes at the Dubai Autodrome with the typical ambient temps may not be doable without some mega ducting and the car may need to be 3350 wet with driver (just an example so the variables are easy to see).
Old Oct 26, 2008 | 04:59 PM
  #65
AlwaysinBoost's Avatar
are you or paul talking about trail braking here?
Old Oct 26, 2008 | 08:24 PM
  #66
yep, do a search if your interested, it was discussed to death a couple of years ago
Old Oct 26, 2008 | 09:33 PM
  #67
RaNGVR-4's Avatar
You dont have to trailbrake to use that technique to try and keep heat down, you just have to brake earlier and off the brakes earlier, so you arent on the brakes while turning in. basically just moving where youre braking to an earlier spot on the track. Its not as fast though, lol
Old Oct 27, 2008 | 05:04 AM
  #68
IIRC the info I read about trail braking is that is generates more heat then straight line braking.
Old Oct 27, 2008 | 06:46 AM
  #69
no, your confusing it, I believe, with left foot braking when your on the brake and gas together at times which causes serious extra heat.
Old Oct 27, 2008 | 09:23 AM
  #70
theshadow's Avatar
my understanding of track braking technique is that you want do NOT want to let the car "coast" - need to be on the brakes 100% or on the throttle at all times (except when you screw up) and spend the minimum time braking that you can.
I brake very hard and very late, always to the point of where the ABS wants to kick in, then I'm on the power right after. I don't "slam" on the brakes but pretty close!
Although this technique seems to faster, not sure if it's good or bad for managing brake temps. I also avoid left foot braking for the same reason - to save the brakes for stopping.
Old Oct 27, 2008 | 10:35 AM
  #71
RaNGVR-4's Avatar
When trailbraking, you arent braking for any longer than you need to, so why would it generate more heat?
Old Oct 27, 2008 | 11:07 AM
  #72
don't know the logic behind why it would generate more heat but I thought it had something to do with turning the wheel while your braking... atleast thats what I remember reading.
Old Oct 27, 2008 | 11:17 AM
  #73
LilRico's Avatar
Originally Posted by EVOBrakes
I would not advise the Brembo 14" kit. Pads are nearly IMPOSSIBLE to source and $texas - I believe it's the same shape as used on the new GTR.
Please tell me I'm not going to have a hard time looking for brake pads when its time! How much is a rough estimate of these pads anyways?
Old Oct 27, 2008 | 11:25 AM
  #74
CBRD's Avatar
stoptechs are the way to go in my opinion... lots of pad variety!!
cb
Old Oct 27, 2008 | 03:08 PM
  #75
cb
I like those as well, we used them to good effect on the AMS TA1 car. I really like that they also have the often overlooked rear calipers as well for a balanced upgrade
