T-bolt hose clamps legal in stu?
Originally Posted by scca rules
"13. STOCK CATEGORY
Hardware items (nuts, bolts, etc.) may be replaced by similar items of unrestricted origin. Safety wire, threadlocker compounds, and locking nuts are permitted. These allowances are strictly to allow components to be replaced from alternate sources other than the original manufacturer. They should not be construed as an allowance to replace components with those which could be considered a ‘higher performance’ alternative."
if the T-bolt clamps aren't considered a "higher performance alternative" then why bother putting them on?
I wouldn't argue that it is a safety OR performance issue. The worm gear clamps hold just fine for stock boost levels. They are a pain in the *** to remove and replace often because they break. What then, do you have to go by "mitsubishi" clamps?
Since the point of the clamp is to hold as tight as possible, I would still say they are legal under the nuts/bolts rules. Of course everyone is entitled to a different interpretation.
I say this even though I use the stock wormgear clamps.
d
d
Ultimately Silencer has already clarified this issue in the past via email. I remember reading about it. Plus anyone who is even thinking about protesting this is the biggest wiennie EVA!
"13. STOCK CATEGORY
Would you consider these a "higher performance alternative"? If not, why bother putting them in the rules.
Could it be for the reason of safety?, no way.
Dave
Eric Lyublinsky
Sep 14, 2013 12:26 PM
R0ME0
Jun 18, 2009 11:55 AM
