Proper sub belt mounting?
Old May 18, 2009 | 01:23 PM
05 MR's Avatar
My Sparco seats arrived and I've got'em ready to install this weekend. From everything I've read (the correct instructions), it looks like the only solution to properly mount my dual (6-point) sub belts is to drill the floor and use a reinforcement plate. If anyone has a solution that keeps the angle to within 20 degrees and avoids drilling, speak now please. I'd like to keep my car such where if I had to put the stock seats back in, pull the harness, pull the cage, etc., I could. I'm not planning on visiting the dealer, but things happen.
Old May 18, 2009 | 01:54 PM
boomn29's Avatar
So you've got a cage and you're still concerned with what a dealer thinks? Didn't ya have to drill just a wee bit for the cage?
I drilled and reinforced. Done. I knew that was the official point of no return. I might have been able to sneak past the darkened calipers back then - which to me is the easy sign of track use.
Old May 18, 2009 | 03:06 PM
05 MR's Avatar
Until my warranty is up, Yes. In another 6 months, no. Pretty sure I could hide it if I had to.
With something like this?
http://www.sparcousa.com/pharness_comp.asp?id=479
If yes, 4 bolts in the 4 corners (not too close to the edges)? Did you then use i bolts to connect the sub belts?
Old May 19, 2009 | 07:36 AM
boomn29's Avatar
I used everything I got from 992gnt actually. The plates look like a D ring and have a backing plate for underneath the car as well. You need to be careful when you drill as there are some lines you have to work between.
I've got some pics at home I'll try to post up tonight.
Old May 19, 2009 | 08:41 AM
05 MR's Avatar
That would certainly help. Thanks.
Old May 19, 2009 | 12:36 PM
jid2's Avatar
Or you can weld mounting plates in.
Old May 19, 2009 | 07:34 PM
boomn29's Avatar
vtluu
16
Jan 8, 2011 07:57 AM
05 MR
May 18, 2009 09:15 AM
Celica2EVO
May 20, 2008 06:34 PM
nicka117
Nov 11, 2006 01:07 PM
Andrew LB
Mar 30, 2006 01:18 AM
