2011 STU Discussion
Old Feb 16, 2011 | 10:29 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Delete! Problem solved.
So my car has illegal motor mounts on it right now - aluminum or something. Anything worth it in the aftermarket or should I just get stock ones?
Old Feb 19, 2011 | 12:16 PM
JDMS60R's Avatar
[quote=Butt Dyno;9083195]Delete! Problem solved.
You should be ok as long as it doesn't have more metal, i.e. solid mount than the o.e. one. I have an lower front mount which is very similar to the o.e. one hopefully no one squawks about it.
Old Feb 19, 2011 | 04:32 PM
Loser's Avatar
Correct me if I'm wrong but I think it's only illegal if it's metal-to-metal. If there's any rubber in the bushings that absorbs the vibrations I think you're fine.
Old Feb 19, 2011 | 07:31 PM
Butt Dyno's Avatar
They were described to me as "solid aluminum engine mounts".
Rulebook sez
Engine mounts may be replaced, but must attach in the factory
location(s) without additional modification or changes. Engine position may not be changed. The volume of metal in a replacement
mount may not be increased relative to the volume of metal found
in a stock mount for the particular application. Solid metal mounts
are specifically prohibited.
So I haven't gotten under the car to check em out yet, but they do vibrate quite a bit at idle.
In Subaru land, the harder rubber ones (Grp N bits) were pretty popular - just wondering if there is an equivalent here.
Old Feb 19, 2011 | 11:45 PM
Jeff_Jeske's Avatar
What is the STU tire of choice this year?
Old Feb 20, 2011 | 07:48 AM
Caffeine Slug's Avatar
Ralliart makes the Group N mounts.
http://www.rallispec.com/prod_chart_evobush.htm
For me anyway, they were really harsh on day one, then over the next few weeks they got broken in a bit. Still noticeably stiffer than stock, but minimal added vibration now.
Old Feb 20, 2011 | 09:21 AM
kekek's Avatar
I've had the Ralliart ones for 4 years in my BSP car. Still working well (dash vibrates). Got them from Z1 Performance, I think pricing is around $180 for the set of 4.
John
Old Feb 20, 2011 | 12:47 PM
JDMS60R's Avatar
Were going to be running the Direzza Star Specs, put a set on the M coupe towards the end of last season, and the grip was amazing over the Kumhos they replaced
Old Feb 21, 2011 | 09:39 PM
Jeff_Jeske's Avatar
Good to know ... Thanks!
Old Feb 22, 2011 | 06:52 AM
Bassicfun's Avatar
Anyone even interested in the New Hankook RS-3 in the 245/40 size? looks to be about $25-30 per tire less than the standard Z1, but was curious if any of the west coast guys have their hands on a set and/or plan to test them. Thanks.
Old Feb 22, 2011 | 07:06 AM
Butt Dyno's Avatar
I'm definitely interested, but since I'm starting from scratch I'm probably just gonna run the proven stuff this year (Z1, AD08). They're appealing for co-driven cars for sure.
Old Feb 22, 2011 | 07:07 AM
blkmkIII's Avatar
Hoping to have a set of those soon on the east, but they will be of no use until april haha.
Old Feb 22, 2011 | 07:55 AM
My co-driver convinced me to try the RS3, should arrive next week.
Old Feb 22, 2011 | 09:21 AM
Bassicfun's Avatar
Great, have events started up out there in AZ? Let me know, would like to see event results even from a local, if there are some quality drivers in the area.
Old Feb 22, 2011 | 11:36 AM
Started up? Events don't stop in AZ! I probably won't use them until late March, just to get an event on them before the SD tour. Handful of national champions and plenty of other good drivers out here for comparison.
