TTS/TTS Weight/Horsepower Calculations
Here is a quick screen shot of a minium weight/maximum HP calculator that I made for NASA TTS/TTU. You can plug in different weight, HP, types of tires, etc. and it will either tell you your minimum weight or maximum HP for that particlar setup. I will post more later . . .
i know mark berrys car would surpass the TTU limits, but that car would fall apart on a road course mini brakes, small radiator, stock intercooler, no cage and gutted as far as humanly possible (i.e. very flexible chassis). oh, and the 3 gallon fuel cell wouldn't help much . there is a lot of weight to add back into the car to not break, not overheat, and make it safe. i suspect it would fall into the range my car is at, 2650-2700 w/driver if he were to convert it to road racing ever (and i have heard him mention it before). however, he knows that there is so much work to convert it to road racing it might not be worth doing.
and i should point out his is on the extreme edge of modifying an evo, by no means a mild hp/weight ratio.
Btw, if I were going to run in TTS/U I would never do it with a dynosheet from a Mustang dyno. That 1.1x conversion is BS. And that's something I'd look into personally. If you don't have access to a non mustang dyno, I'd try to find one somewhere just so you can get an apples-to-apples sheet. Just my .02
For example, I know AMS's new Mustang dyno is exactly 8% lower than their old Dynojet. .8% vs 1.1% is huge!
500whp on AMS's Dynojet x 0.92 (eight percent less) = 460whp on their Mustang Dyno
460whp on their Mustang Dyno x 1.1 NASA correction factor = 506whp
VERY close numbers when comparing two dynos.
So let's say a very light TT EVO at 2700# with driver - that only allows you around 450whp on a MD or about 500whp on a Dynojet. Sure - a crazy fast combo - but not even close to what the Unlimited class RTA guys are running . . .
Just to get an Evo down to 2700# with driver takes some dedication to say the least. You'd be completely insane to do it w/o a cage and full safety gear, so be sure to factor that in.
Anything below 3000 (with driver & cage) has a lot of work in it. That's removing a good 500 lbs from the factory. I know mine would be down to 3120 w/o my rollbar. But that's w/o a cage and really no excessive gutting (all windows, door bars & front/rear crash beams still there).
But yeah, I get your point. Let's say a 3000 lb car for TTU max on 275's needs something like 575whp dynojet. But I'd think you're long past a DOT and should be running full slicks at that point. I don't have the conversion #'s worked up for those.
The thing is, other TTU cars can make that 5.5:1 ratio with a good powerband. Think american V8 - modded Z06's and Vipers ACR's hit that with room for wider tires, better gearing and much better aero. It's an uphill battle for Evo; no doubt.
Hell, for mostly the same reasions, I think TTS is an uphill battle on a lot of tracks!
