Brake Ducting Thread
Old Apr 7, 2011 | 07:27 AM
Velcro_Treefrog's Avatar
How much of a different do these cooling lines make? It would seem that with the roughness of the hose and the multiple kinks that losses would be pretty significant and getting a significant amount of air through the hose without a fan forcing it through would be very difficult. (Serious question, just looking for input based on experience. I heat-cracked my rotors once at a track day so I'm curious).
Old Apr 7, 2011 | 12:52 PM
Hiboost's Avatar
Hold the end of a 10' section of the tubing out the window and blow it back at your face after twisting it around in the front seat. I bet it has quite a bit of airflow!
Old Apr 7, 2011 | 01:06 PM
Ryan.Kauz's Avatar
Originally Posted by JDavenport
When installing the front brake ducts on my Evo, I was not (and am not) happy with the length of hose run and number of bends to get to the front end.
There are pics scattered in some other threads of different approaches to this issue. Please post any pics/info in this thread you would care to provide.
I am particularly interested in NACA ducts. Saw some pics where a Subie guy installed them in the undertray. How well does this work?
Or use the search function and post in the threads already available.
https://www.evolutionm.net/forums/mo...cts-setup.html
Note: the link above has multiple options and input from various systems currently in place by others.
Old Feb 29, 2012 | 09:29 AM
delongedoug's Avatar
I'm looking to run a brake duct kit this year and right now my only concern is where to mount the inlets on the bumper. I have an Evo 8 with an ETS intercooler taking up the entire center section. What I see almost everyone do is zip tie the ducts to the bumper mesh in the side bumper openings. However, my bumper has neither the mesh nor the tabs required to mount the mesh. So, that leaves me with a big gaping hole and no way to mount the ducts. What I'm thinking I might want to do is buy a duct like this:
http://www.racerpartswholesale.com/p...39/Naca_Ducts2
And drill it and my bumper and zip tie them up. This could get incredibly ugly so the first step I think will be measuring that bumper opening to see what I'm working with.
I'm completely open to suggestions.
Old Feb 29, 2012 | 09:44 AM
DaveK's Avatar
^ That's what I'm running on my car, using an Evo VIII bumper.
If you look closely you can see them stuffed in from the back side. I did do quite a bit of trimming of things to get them to fit more square to the bumper, and I don't have an oil cooler or ACD pump sitting in the fenderwells anymore, so this may or may not work in your application.
Dave
Old Feb 29, 2012 | 09:52 AM
I was about to say, I don't want to block off the entire opening with a brake duct because I still have the oil cooler that needs air as well (no ACD, though). Hmm, maybe a smaller duct like this in the corner of the opening:
http://www.racerpartswholesale.com/p...44/Naca_Ducts2
That would keep the rest open to flow to the oil cooler while giving me at least 2 mounting points.
Old Feb 29, 2012 | 10:03 AM
DaveK's Avatar
I have a set of those too. Didn't end up using them as we welded on a 3" metal adapter to the AMS duct kit so I could run 3" piping all the way back. LMK if you're interested in 'em, could probably get them boxed up in the next day or two.
Dave
Old Mar 1, 2012 | 06:49 AM
mouseIX's Avatar
Porsche Cayenne's have a nice aluminum NACA duct that is attached to the plastic underbody panel to cool the trans and diff. Everytime a car comes in with a damaged panel and the customer buys a new one I drill out the NACA duct. I'm in the process of making a front spilter/undertray that I will incorporate these ducts into. It's a slow process but I will post pictures of the final product.
Old Mar 1, 2012 | 07:22 AM
Kidloco51's Avatar
My new 3" helicopter tube. Super flexible and heat resistant.
Old Mar 1, 2012 | 07:25 AM
MyEvoDream's Avatar
Kidloco, any pics of the bumper with ducting on the? Would like to see how they route to the brakes if possible. Love the innovation going on in these brake ducts threads...looks like I have a project for spring time
mhershorn
Mitsubishi TC-SST Discussion
Aug 29, 2013 05:15 PM
EGbeater
Oct 12, 2011 07:42 AM
chu
Oct 26, 2009 02:38 PM
KazzEvo8
May 12, 2009 07:27 PM
MikeRR
Dec 8, 2008 09:54 PM
