2011 MT washington here i come!!
Old May 23, 2011 | 09:14 AM
  #46
DaveK's Avatar
Originally Posted by Robevo RS
the oem heater box vs the new one.... LOL
and still cutting out parts from the car and the doors. we were able to take out over 10lb each door!
That's the same heater that's going in my car too!
Question - I thought that gutting the front doors wasn't allowed unless you are going to an FIA approved foam door cell? If I read the rule wrong, curious what areas you removed?
Rears doors are free to modify - and can even be composite now.
Dave
Old May 23, 2011 | 12:53 PM
  #47
Robevo RS's Avatar
Dave
yes you are right, we did only modified the rear ones. And still yield for ~20 lb weight loss.
there is a crash bar inside and the window railing , window motor and mechanism+ the metal cover layer of the doors + harness .
i have no $3000+ for front doors to be lighter . It is just silly for me to do that, so the stock doors stay as they came from teh factory. It is stupid since there is the place where the cage is a most sturdy so i do not think it does any difference if you gutting them.
the heater box alone made around ~13lb weight savings. Not to mention the room!
Old May 23, 2011 | 12:55 PM
  #48
Robevo RS's Avatar
Originally Posted by AlwaysinBoost
wow, looking GREAT Rob.
Old Jun 5, 2011 | 06:56 AM
  #49
Robevo RS's Avatar
ok , as today the painting is done. NOw officially the rebuild starts !
Only the two ECU is missing form the table , but next week my parents will bring them from Europe .
here is some pictures from the painting and when its done .
seem welds done also, and the de greasing is done
now the painting usually the pictures made after 10 pm LOL not surprising i wasn't smiling ..
ready to go back to RKT motors.
Old Jun 5, 2011 | 08:28 AM
  #50
jerdeitzel's Avatar
Looks good Rob!
I'm getting excited. I just need to do some final tuning on the car and i'm ready to race.
Old Jun 6, 2011 | 01:57 PM
  #51
DaveK's Avatar
Looks great! Now go get some dirt on it...rally cars shouldn't be that clean.
Dave
Old Jun 8, 2011 | 03:51 AM
  #52
Robevo RS's Avatar
Dave
Dave asap.... LOL
here is the new engine pictures , part of it
this weekend new ECUs and tune !!!
Old Jun 8, 2011 | 07:02 AM
  #53
Balrok's Avatar
Which Ecu's?
Old Jun 8, 2011 | 10:35 AM
  #54
Robevo RS's Avatar
Originally Posted by Balrok
Which Ecu's?
GEMS Engine Ecu and GEMS ACD ECU with 5 settings
The proper rally set up.
Old Jun 8, 2011 | 04:07 PM
  #55
Balrok's Avatar
Dammmn, if you get extra's i'll do double stints on the bike for ya!
Old Jun 10, 2011 | 05:48 PM
  #56
jerdeitzel's Avatar
Things just got even harder in open class!
David Higgins from Subaru USA rally team is running a Vermont sportscar prepped Suby in open class. "an evolution of Pastrana's record setting car"
http://vtcar.com/2011-06-10/2897/
I'm playing with the big dogs this event.
Any sponsors want some add space?
2011 Sponsors
JESTR TUNING
http://www.jestrtuning.com/
Old Jun 10, 2011 | 06:24 PM
  #57
DaveK's Avatar
Sucks you guys have to run restrictors - that's one of the things that allows privateers to catch up to the big guns on a budget.
Best of luck!
Dave
"still wishing they'd have put this on any other weekend of the year...grumble grumble"
Old Jun 10, 2011 | 07:04 PM
  #58
jerdeitzel's Avatar
I can understand the grumble's. .
I hope thats the case with the restrictor. I'm suprised how good the car still feels with it in. I think my car can be competitive on the tarmac part and hopefully i can just keep it together in the gravel.
Old Jun 10, 2011 | 08:01 PM
  #59
DaveK's Avatar
Crap...poorly worded statment on my part. IMO the restrictors make the gap bigger between the higher & lower budget teams...sort of. You can make similar peak HP numbers as a factory team, but with racing its area under the curve that gets a restrictor car cranking down the road. A team with the resources to replace parts often will run a crazy high compression ratio, tune for the edge, and run aggressive antilag. This means powerband more like a diesel motor, but big area under the curve.
On the flip side, when not required to run a restrictor, here's what I've found:
You can choose to make power in a cheaper manner - a larger turbo. I've run against guys with full blown stage rally cars on hyper antilag, and at the top of the hill, we're always close. They pull out of the corners harder with the smaller turbos and antilag, and I make up the speed on the straights with a bigger turbo and no antilag. Of course the fastest way up the hill would probably be a large turbo on antilag, but then you'll be blowing up turbos and axles. Well, that and close racing is fun racing.
For tuning on a restrictor (what size do you guys have to run?) sometimes the key to gaining a little bit more power under the curve is to heavily taper off the boost in the upper revs.
Dave
Old Jun 10, 2011 | 09:14 PM
  #60
jerdeitzel's Avatar
We are running 40mm.
I am going to do my best to get as much Tq as possible. I don't think that high hp is really much of a factor as i believe the top speed record in one section is just over 100mph. It will be a matter of getting out of the bends the quickest. Traction doing that, is going to be key.
