evo setup for autox stock class
Old Jun 12, 2006 | 10:01 PM
  #211
Ro's Avatar
Ro
Originally Posted by point&shoot
Both of those tires are great choices if you want something that will last more than one season. People who have them tell me they put them on at home and drive to the autocross with them, so that's a great convenience (you don't have to get to the event 1/2 hour early to change wheels). But you're right, they're not on a par with the Kumho v710's, which by the way are not quite as sticky as Hoosiers, although they're cheaper and last longer. It's all a trade off of money for performance and convenience.
Oh, one more piece of advice that may be specific to the Evo. I just discovered this when switching from street tires to R-compound, and switching between rain and dry: the stock Evo has the strange property that the more traction you give it, the more it will understeer. On my street tires, I used less pressure in the rear than the front, just like it says on the door jamb, and the car was nice and loose. I could rotate it just by lifting throttle in a sweeper. When I put on the R-compound tires, the car was pushing everywhere. I asked a top driver of an Eagle Talon about it (he runs the same tires, and is AWD), and he said that with the Kumhos (or any R-compound, I guess) you have to overinflate the rear tires to reduce the contact patch and make the car neutral again. He uses 8 lbs. more in the rear than in the front. I tried it and it worked great! Except than it started raining and the car was too loose, and I had to let some air out of the rear.
Just a tip.
yeah, it looks like a common theme on the autocrossing evos: +5 - +8lbs in the rear.
Old Jun 13, 2006 | 11:07 PM
  #212
point&shoot's Avatar
But just to reiterate: if you do that with street tires, even the very sticky OEM tires, you will be way too loose (at least for me, and the instructors who drove my car). Higher pressure in the back is the right setting only for R-compound.
Warning: Technical Geek Analysis follows:
I think maybe the reason that the stock Evo pushes more, the more traction it has, is that the front sway bar is too strong compared to the rear sway bar. At high traction levels (i.e. high suspension-compression levels), it's transferring too much weight from front to rear, resulting in understeer. I say this even though I have observed that the inside rear tire lifts two inches in a full-G turn with R-compound tires. The Evo is basically a front-wheel drive car with some power sent to the rear wheels as needed. It doesn't need any traction from the inside rear wheel during cornering. What it needs is a lot of weight over the front wheels, since the center of gravity of the vehicle is so far forward.
Has anyone tried installing a weaker front sway bar on the Evo, for stock autocross? I'm curious whether that reduces the variation in oversteer vs. understeer across different traction levels.
Old Jun 23, 2006 | 08:08 AM
  #213
rburris28's Avatar
Talking
Here in Western NC, the lots are small and the courses are tight; I run 37-38f and 42-45r (thanks Racerjon!) without problems. I can say that if you forget to air them down, the drive home can be eye opening!
Old Jun 23, 2006 | 08:10 AM
  #214
rburris28's Avatar
Originally Posted by Solo Evo
Fender rolling is not legal in stock classing. You shouldn't need it anyway with 275s, just a +33 offset will do it whether by wheel offset or spacers.
Devin
I sent you a PM on the Highlands site about which tires you recommend; the V710s (and which width) vs. the RA-1s you ran the last two times with Highlands. Any advice is appreciated: I want to try to get at least within two seconds of your times!
Old Jun 28, 2006 | 06:30 PM
  #215
Loser's Avatar
Last weekend I ran with the current setup on a wet course (car is completely stock)
Camber f/r: -0.8/-1.7
Toe f/r: 0/0.05
Tire pressure f/r: 33-34/29-30
The reason for the unusual camber was because the technician wasn't able to get more negative camber in the front. It was only after I got it set that I read on here about the unusual eccentric bolt.
(read here https://www.evolutionm.net/forums/sh...eccentric+bolt )
The autox course was wet from raining the entire night and a light rain that persisted throughout the event. I ended up doing remarkably well, winning my event in AS, and beating all but one of the modified Evos and STis in higher classes. Some of the drivers lucked out of having good runs because a wannabe drift-king wiped out the timing equipment which caused a delay long enough to bring in some hard rain.
My question is was it just that the rear had more grip than usual, or the fact that the rear had more negative camber than the front that helped me? In other words should I keep this setup or increase the negative camber in the front?
Thanks.
Old Jun 28, 2006 | 09:40 PM
  #216
Boder's Avatar
Toe f/r: 0/0.05
Thanks.
You must have just driven a lot smoother than the others. That is the key in the wet. Your setup screams understeer. Even in the wet.
Do as everyone else says. Max out the front negative camber with the not so unusual ecentric bolt(used on many "sporty" cars ). Put 5-10 psi more in the rears than the front. In the rain, I use around 4-5 more psi in the rears for a little more stability.
Old Jun 29, 2006 | 06:12 AM
  #217
chmodlf's Avatar
Right on
Old Jun 30, 2006 | 08:44 AM
  #218
Loser's Avatar
I guess I was smoother. We'll have to see at the next event if it was a fluke or not
So hopefully I'll get the extra negative camber on the front before the next event. As for tire pressure, I've always gone for the pressure where the tire wall is on the verge of rolling. Wouldn't that be the pressure that gives you the most grip? Any lower and the tire will roll, any higher and you'll start reducing the contact patch, or make the tire too stiff and thus reduce grip. At these pressures I find that the car rotates quite predictably and doesn't feel twitchy. So why have more pressure in the rear? BTW my car is an RS, so I don't know if the weight in the rear is significantly less than in a GSR or MR.
I suppose that I could be running at a pressure where the tire wall isn't rolling, but the tire still flexes a lot. Is that what you hope to prevent with the high rear pressure?
Thanks for the tips guys.
Old Jun 30, 2006 | 09:11 AM
  #219
jbrennen's Avatar
You've definitely hit on something important here.
The tire sidewall is part of your suspension. It's an adjustable part of your suspension, even in Stock class. If you don't have adjustable shocks, it's probably the only part of your suspension which is adjustable between runs (although I could imagine somebody adjusting rear camber/toe between runs, I can't imagine that anybody would actually plan to do so, because you'd have to work really fast and get it right the first time). By running higher pressure in a tire, you're effectively increasing the spring rate at that corner of the car.
Now of course, tire pressure has the other "side effect" of changing your contact patch size, and you do need to take that into consideration.
But there is no "magic setting" for tires that works best -- running at the point of impending sidewall "rollover" might be giving you a good contact patch, but also allowing too much vertical deflection between the ground and the chassis.
Try different pressures, including some much higher than you might think. I used to run my A046 tires as high as 44 psi and they seemed to work pretty well, plus making the car feel much crisper in transition. You could learn something useful. And trust the way that the car feels rather than looking at a gauge or a line of chalk or shoe polish on the tire.
Old Jun 30, 2006 | 01:23 PM
  #220
CDeutsch's Avatar
I was running over 50psi in the front with the A046s at the last two AutoX's and I'm still about scrubbing the wear indicator triangles. I wonder if that's too much?
On a related note, does anyone else run in STU? I'm hoping to participate at Nationals this year. It sounds like a fun time!
Old Jul 2, 2006 | 05:31 PM
  #221
Loser's Avatar
Will do. Although the last time I ran such high pressures I didn't like the feel of the car at all, so I dropped the pressures down. Then again, it was on cold tires, so I probably didn't give it enough time to warm up. I'm more comfortable running with the lower pressures, so maybe I'll bump up the pressures for fun runs, or if I'm completely off the pace at the next event
I see you're in/from San Diego. I'm in LA for the weekend. Drove down to SD early this moring to see the Wild Animal Park, just got back to LA. Drove some canyon roads yesterday in my brother's 350Z. I love this state, absolutely hate the Northeast (sorry NE people).
Old Jul 11, 2006 | 08:31 AM
  #222
jwtodd60's Avatar
Originally Posted by jwtodd60
And it appears to be hollow as well. The Tanabe sounds like it was hollow too, a little smaller though, but chrome-moly and a lot cheaper. Too bad neither one listed all of the necessary details to make a fully informed decision. Oh well, nothing new there, at least we have choices now...
JW
Some of you may have seen this thread already, but Ralliart Italy has a 29mm front sway bar if you are so inclined. 990 Euros though...
https://www.evolutionm.net/forums/sh...d.php?t=210798
JW
Old Jul 23, 2006 | 09:34 PM
  #223
Boder's Avatar
I got new V710s and tried them out this weekend. I went with the 275/40/17 front and 245/45/17 rear like I said I was going to in earlier posts. After getting used to the front tires rolling over a little more, the setup worked great. I found that setting the front shocks to full stiff and the rear to 5 clicks off of full stiff on the Ohlins was good. I had my pressures set to 47F and 44R.
The results of the event aren't posted yet but I think I PAXed decently overall. I got 2nd in AS.
To anyone running the 275/40/17, what are you using for pressures?
Is anyone going to the Seattle National Tour in Packwood, WA? I'll be there.
Old Jul 24, 2006 | 11:17 AM
  #224
SS RX7 r2's Avatar
That sounds around 10lbs too high. The 710s like low pressure, but it may be needed on an AS car.
I wish I had time to do the Packwood Pro, I need to get some more points for the finale.
Old Jul 24, 2006 | 02:33 PM
  #225
rburris28's Avatar
I am getting ready to run 275/40/17 V710s in AS this weekend and I have looked everywhere I can think of for guidelines, but they are confusing; most of them apply to V700s, some say go low, others high.
I was pleased with 38f 45r with the stock Advans, but have no idea where to start with the V710s. Would you please share some of your experience with me?
There's a big trophy on the line for fastest turbocharged vehicle (by SCCA Pax)!
