evo setup for autox stock class
Just an FYI for anyone wanting to add to their a-stock setup; my double-adjustable koni shocks are up for sale, see here: https://www.evolutionm.net/forums/sh...d.php?t=239080
Devin
Devin
- any exhaust AFTER the cat is allowed (90db noise restriction)
- any brake pad and rotor of STOCK SIZE is allowed.
- any alignment settings within the range of adjustment capable of the stock parts.
- any FRONT sway bar (or removal of) is allowed. all other must be stock.
- aftermarket shocks of STOCK SIZE AND TYPE are allowed. This allows adjustable shocks, but not edfc or the like.
- any tire that fits properly on STOCK SIZE AND OFFSET rim is allowed, and must be DOT approved
- any rim that is the SAME SIZE AND OFFSET as stock (+/- .25") is allowed.
That mean drilled or slit rotors are ok for stock?
The wording for Stock class which covers brake rotors:
Alternate components which are normally expendable and considered replacement parts (e.g., engine and wheel bearings, seals, gaskets, filters, belts, bolts, bulbs, batteries, brake rotors, clutch discs, pressure plates, suspension bushings, drivetrain mounts, etc.) may be used provided they are essentially identical to the standard parts (e.g. have the same type, size, hardness, weight, material etc.), are used in the same location, and provide no performance benefit.
Now that my A046s are almost done I've been giving some serious thought to what tires I should use this year. Last year I ran the car completely stock in AS and plan to do the same this year except for tires. I still have a lot to improve, but towards the end of last year I found myself sometimes about 0.5 - 1 seconds on a 35 second course behind some of the competitive S2000s on R-compounds. So I've been tempted to see what I'm capable of with better rubber.
Due to price, treadwear, and reviews such as the following I can't think of anything else other than the Toyo RA1s.
From https://www.evolutionm.net/forums/sh...ght=A046+toyo:
But is it worth it? Will moving to R-compounds hide my mistakes? How much faster would they be compared to the A046s on a 35 or 45 second course? Would I be better off investing in a lighter set of wheels for around the same price?
The Toyo RA1 is the only tire you can even think of driving on the street and the track. Be warned that once the tread blocks are worn off, you have 4/32 rubber left but they then become like the other R compounds, only lines no tread, so stay away from water. As for wear, nothing even comes close. This tire isn't the best choice for the serious AutoX guy, but it makes a fantastic lapping or track day tire. You can easily get multiple track events out of these. You will not get that from any of the other R compounds. Yes, you can run a Hoosier, Kumho, Hankook, etc... but they will be long gone and you would be better off putting the stock Advans on.
RA1s are an interesting tire, because they behave differently from street tires while also behaving very differently from Hoosiers. (Can't speak for Kumhos personally.)
You may find that RA1s are fastest when you "drive it like you stole it"... Even before you start sliding the tires, they'll outgrip a street tire, but they really shine when you start pushing the tires beyond that point. Among all of the various tires I've autoXed an Evo on, the RA1s were the only tires which just got faster and faster the harder you pushed. (As long as you don't push beyond the driver's ability.)
As a result, I've found that RA1s are really fun tires for autoX, even though they may not be the fastest R compounds.
I wouldn't worry about "hiding your mistakes" on RA1s. What I would worry about is that once you've gotten used to RA1s, virtually any other tire that you switch to in the future will probably demand a bit more conservative style of driving.
The right rubber can easily get you a second on 35-second course.
Regarding the cordless impact wrench... The cheap way out is to get a square-drive bit for a cordless drill. Use a lug wrench to break the nuts loose, spin them on and off quickly with the drill, and torque with a torque wrench.
If you've already got a cordless drill, you can avoid buying a cordless impact wrench if you're willing to break the nuts manually. Torquing should be done manually, whether you use a drill or an impact wrench--don't trust an impact wrench to get it right.
Also, if you stop the wrench about 1 sec after the nuts stop spinning, you will find that they're torqued almost perfectly to 80 ft-lbs. You should still check them with a torque wrench, and I do, but I usually find that the torque wrench has no work to do on most of the nuts.
With this wrench I've got my wheel-changing time down to 15 minutes each at the beginning and end of the event (that includes getting the wheels out and packing them up in the back seat).
Oh, I also should have mentioned that the US General portable racing jack from Harbor Freight is indispensable, as well. Much higher quality than the stamped steel things from China that you find at places like the AutoZone.
Thanks for the info guys. A friend of mine also suggested the Kumho VR 700s. Tirerack sells them in 245/45/17 for $157 whereas the cheapest I've found for the Toyos are $168 in 235/45/17 at bmwwheels.com.
I live about 75 miles from my two favorite autox courses, so I think driving to them on these shouldn't be a problem. But I'm still undecided if I should go for R-comps yet. There are a few experienced guys who are faster than me on stock A046s, so it wouldn't satisfy my ego if I can't beat them without going to R-comps
So do you think that's a big problem when you eventually want to move onto really good tires?
That seems to be the best plan.
Exactly what I wanted to hear.
And I said that the torque wrench takes them right about to 80 ft-lbs, as proven by the fact that I get a a little more tightening on some of the nuts when I check with the torque wrench.
Look, you can't be too **** about the tightening specs. One trip to the tire shop to have your snow tires put on, and you're going to find your wheels torqued to over 100 ft-lbs (unless you specifically warn them and they have good customer service). I've had lug nuts put on so tight that I had to jump on the breaker bar to get them loose, and they didn't fail.
The quickest way to have your lug nuts fail, and it has happened to me at least 5 times, is to have them loosen up while you're racing. Then they're going to be badly stressed. That was happening to me all the time before I upped the torque to 80 ft-lbs. I now carry at least two spare lug nuts and wheel bolts with me for any racing event.
No I'm not overtorquing them. I'm torquing them to 80 ft-lbs, which is within the spec of 73 +/- 7 ft-lbs. I used to use 75 ft-lbs, but the front wheels kept loosening up during autocross competition. 80 ft-lbs is the minimum that keeps them from doing that, at least for me.
The good news is that it only took me half a season to learn how to drive on R-compound, and now I'm getting the full performance advantage from them. (Now if I can only learn the right racing line for autocross...)
The specs for a DSM and 3000gt/Stealth are 87-101 ft. lbs. So I wouldn't be afraid to crank it up a little.
