evo setup for autox stock class
Well, my OZ was deemed totaled by the insurance company after multiple electrical problems ( it was stolen Nov 9 but recovered Nov 24 ) so it looks like i'm making an early jump to AS.
One thing i was reading thru this thread - is a TBE not legal ? Sounds a bit odd that a cat delete or a HFC is ( from what it looks like to me ).
Ugh. Looks like i jinxed myself.
^ you're right. I finally found the exhaust issue on my region's site......
Anything available on the exact model and year of your car as standard or optional equipment, as installed on the factory assembly line (nothing available only dealer-installed is allowed), plus
Standard OEM identical replacement parts
Accessories, gauges, appearance, comfort, and convenience items (not replacement driver's seat, though) that basically don't help
Added roll bar or roll cage to spec (not required, though)
Driver harness (no cutting seats to install, though)
Trailer hitch and/or tow bar mountings
Any wheel of diameter and width identical to a stock or factory optional wheel, offset within +- 0.25 inch
Most street legal tires that will fit the mounted wheels and stock bodywork
Any shock absorber of the same type and mounting as original; no change to standard spring mountings is allowed; suspension geometry may not be altered; gas or hydraulic shocks are permitted
Any brake linings; pre-1992 cars may use solid/braided metal brake lines.
Any front anti-roll bar (no change to stock/optional rear anti-roll bar, if present)
Manufacturer specified ignition settings only
Any replacement air filter element (or removal of air filter element); no plumbing changes, however
Engine bored no more than .020"; no balancing or porting/polishing of head
Replacement of any part of the exhaust system past the catalytic converter (if quiet)
Any oil filter
Added clutch scattershield
Any oil filter
Over the last couple of days I've read over this thread. I was wondering if anyone had purchased, or used the 27 mm front sway bar from Do-Luck? Also, is it still accepted that 2 degrees camber up front and 0 toe, with between 1.0 to 1.5 degrees rear camber and 1/16 toe out in the rear, for alignment ? Right now, I only have my Swift spec-R springs in. (please don't mistake my (springs only) mod as an inexperienced driver qualification, as I kart often.) I am getting my alignment dialed in on Tuesday, so any advice will be appreciated . Thank you.
^this is the Astock thread... so I am not sure you are aware the springs do bump you up to STU or BSP depending.
however those alignment specs are good and currently what I run in Astock.
Car seems pretty neutral and responsive to throttle imputs.
You did pick some pretty good springs however.
Good luck to ya!
Good luck to ya!
Good luck to ya!
Good luck to ya!
Thanks guys, I found good information here and just posted, sorry for clogging up the thread.
1/4" spacer is 6.35mm. Would a 5mm do the job or would it still rub? I ask because I have a 5mm spacer set sitting at home. Where would I get a 1/4" spacer?
I used a 5 mm spacer on the fronts only and had no problems. Don't use them on the back, as the wheels will rub the fender lips.
The increased track in the front seems to help understeer, as well.
Even utilizing the max offset allowance, you will still rub a little on the inner fender liner in the front - at least I do. I've also done little lightening of the front end by dragging the MR underlip spoiler diving into corners. I'm trying the 'kooks this season as they are just a little less wide and should spin a little easier off the line.
George M
George M
