BFG R1-S Test and Tune
For Pw/Wt and points, I need to stick with the 245 DOT tires. BFG 245 gets hit with the added .4. So, the question is:
Hoosier A6 245 VS BFG R1S 225?
Accordng to BFG, they recommend up to a 9in rim for their 225's (keep in mind how much wider BFG's run than other tires).
Jeremy, Did you guys get any data that says the tires are faster or was this just a test fitment testing day?
Andy, I have read that the smaller size BFG's are not as overly wide as the bigger size's. Also, i kno you are pretty much set on running a 245 vs a 275. But, i kno that Nathan did some testing on running both sizes and it might be something to talk to him about.
We'll have to see i guess.
No we did not use any DA. And no, the primary focus on the TnT was to dial my suspension in. And we were successful there.
You understand this is not something I plan to try. Just a suggestion for the other guy.
22.4 whp may be a lot, depending on what you are starting with. If you are already over about 350-375, then I would say no. Josh Dunn has been very fast here on 245 width hoosiers. Personally, I'd take the extra width over 22.4whp.
I'm still on 9.5in wide rims. If I step into a 275 tire, I should find some 10-10.5in wheels. Then I get to add my rear fender flares.
If I were to add another 100lbs, I could squeeze in some 275's. hmm... Right now I'm at 398whp and about 3000lbs.
