Placement of Go-Pro?
Old Jun 7, 2013 | 09:38 AM
ca18hatch24's Avatar
This may be a dumb question, but how/where do you guys like to mount your Go-Pro cameras while on the track? I want to mount mine so that I can see what is happening inside the car, i.e. shifting/hand placement, as well as be able to see out the front windshield. I tried this last weekend by mounting the camera to the inside of the rear windshield....but the camera just focused on the inside of the car.
Any tips on mounts or locations?
Old Jun 7, 2013 | 10:02 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I picked up a harness bar to use as a camera mount because I didn't like any of the window positions and I don't have a sunroof (because racecar).
You can always fab up something like Smike did:
https://www.evolutionm.net/forums/mo...mount-how.html
Something to consider in regards to the harness bar that I didn't think about until recently is that the harness bar is going to prevent the seats from folding back in the event of a roll-over.
If you aren't running a roll bar and a harness when you roll, you're pretty much ****ed.
Old Jun 7, 2013 | 10:04 AM
heel2toe's Avatar
I like mounting mine with the suction cup to the sunroof. Then I just take off my rearview mirror so it doesnt block the picture. Note that this is for auto x purposed though. I wouldnt recommend removing your rearview mirror on an open track.
In your case since you have an SE you dont have a sunroof so I dont really have a good solution for you. If you have a cage or harness bar then that is s simple mounting point.
Old Jun 7, 2013 | 10:26 AM
Dallas J's Avatar
Veteran: Army
Ive been using the rear side window at the front of the door and tilted at 90deg. I can get a good view of drivers hand, in the mirror can see where Im looking, and see how close Im getting to cones.
Old Jun 7, 2013 | 11:56 AM
Thanks for all the suggestions guys...I may try Smikes setup like golgo suggested. Anyone use the Buschur camera mount between the rear seats? Seems like it would mostly just pickup the action inside the car and not the track.
Old Jun 7, 2013 | 12:24 PM
SilverShadow03's Avatar
Here's another thread talking about the same thing...there are a lot of responses and links for accessories ...
Hope this gives you more ideas!
GoPro Mounting Ideas
Old Jun 7, 2013 | 05:36 PM
killerpenguin21's Avatar
yup, i like this one too when no instructor is in the car. helps if you lay the passenger seat back a little too. very clear view of entire driver.
Old Jun 9, 2013 | 02:54 PM
neemo6's Avatar
I agree with what others said and placing it on the rear window. Ive also seen people doing more multiple cameras. With the app and wifi bacpac this works great.
Old Jun 9, 2013 | 05:02 PM
Pure EvoIX's Avatar
while on the topic of gopro mounting locations, how and where does one mount to capture the pedal action without obstruction of the legs. Do you mount it from behind? Do you clamp it on the top of the brake pedal looking down? How do you capture the pedals/foot cam? List materials/tools/mounts used and list where exactly it is mounted.
Yes, I tried mounting on the oem slider bar on the seat, but the legs are obstructing the view of the pedal work. It will not stick on the side of the door via curved and flat mounts or on the side of center console using said mounts. My legs would hit it and will be in the way. Same with mounting on the vertical part of the dash that goes below the steering column. It won't stick there either.
Old Jun 9, 2013 | 05:13 PM
Pure EvoIX's Avatar
For your viewing pleasure.
Nurburgring VLN configuration.
mounted on the moonroof, inverted the video in camera.
2013 Redline Time Attack Round 3
Chuckwalla Valley Raceway CW
mounted on the ioport camera mount located on the horizontal part of roll bar.
KennyRS
Jan 22, 2017 08:27 AM
SnailSpeed
Jan 16, 2016 07:10 PM
InjectedPerformance
EvoX 'For Sale' Miscellaneous
13
Oct 7, 2010 02:10 PM
TommiM
For Sale - Miscellaneous Automotive
21
Aug 17, 2010 07:09 AM
Evasive EVO
107
Jan 28, 2010 03:20 PM
