Made some offset +caster/ camber plates for Ohlin DFVs
Old Sep 28, 2015 | 06:15 PM
JDavenport's Avatar
I've got the CDR plates with the PSRS+Offset, and as noted. This setup lets you get the wheel back in the center of the wheelwell. I ended up with 5.8 Caster.
Old Sep 29, 2015 | 09:36 AM
RJones's Avatar
I'm at closer to 7 degrees with the offset PSRS and CDR plates maxed. With that much caster I ended up hitting things up front when turning.
Old Sep 30, 2015 | 04:43 AM
honda-guy's Avatar
i got about 5.7* of caster PSRS and TFworks caster plates.
Old Sep 30, 2015 | 10:46 AM
heel2toe's Avatar
6.2* here with the PSRS and CDR plates maxed. Differences in rake is what's causing varying degrees of caster with the same parts...
Old Sep 30, 2015 | 11:38 AM
LetsGetThisDone's Avatar
I have 5.3* of caster with just the PSRS. Would like to get some adjustable upper plates to bring the tire back a smidge. And more caster never hurts. I run around 12* on my offroad car.
Old Oct 20, 2015 | 02:44 PM
Nimpoc's Avatar
Originally Posted by Dallas J
No clue since I've never actually aligned the car at a shop. I do have another set of blank plates if you want to add them on when you pick up those springs.
If you've still got those spare plates, I'll buy them from you. If not, might you share the .dxf? I'm kinda buzzing my fender liners.
thanks!
Old Oct 20, 2015 | 04:24 PM
Dallas J's Avatar
Veteran: Army
I don't have the other plates available still but if you pm me your email I'll send you the .dxf
Old Oct 27, 2016 | 11:09 PM
Nimpoc's Avatar
Just wanted to post up a thanks to Dallas for sharing the design. I had a set cut locally ($60) then anodized (hook-up). My trimming of the upper bearing support turned out a little different and in the future I'll probable add the fourth fastener back in.
Alignment results for the following set-up:
Struts bolts are in the -1deg position, offset Duroball control arm bushings and Whiteline roll-center kit. Ride heights are ~25.75"F & ~25.5"R (GND to fender).
Drivers side -3deg camber, 5.6 caster. Pass side -3deg camber, 5.2deg caster.
Dallas J's high caster camber plates for Ohlins.
Upper bearing plates modified for strut tower pinch bolt clearance.
Passenger side, -3deg camber, 5.2deg caster. Strut camber bolt in the -1deg position.
Driver side, -3deg camber, 5.6deg caster. Strut camber bolt in the -1deg position.
Old Oct 28, 2016 | 04:41 AM
honda-guy's Avatar
nice, looks like they worked out good
Old Oct 28, 2016 | 02:44 PM
kyoo's Avatar
not bad & very cheap! I got the ciro plates, and that + the superpro bushings, I've got 5.3 deg of caster & running -3.3 right now
Old Oct 28, 2016 | 03:10 PM
Hmm. I get 5.3* with the PSRS. I was asking Dallas about getting these a while back. I kind of dropped the ball on it.
Old Oct 28, 2016 | 05:59 PM
Dallas J's Avatar
Veteran: Army
Awesome dude, glad you made them and posted pics.
I have recently worked on eeking out the last bit of range from these and I'll probably CNC a new set for myself if anyone wants my old ones for a few bucks. New ones I might make from 3/8" plate and core out to take out a few extra grams and because I can .
doncarbone
Apr 21, 2020 01:15 PM
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
GTWORX.com
83
Dec 30, 2016 05:15 PM
Bassicfun
26
Aug 23, 2016 01:18 PM
mrwickd123
11
Jul 13, 2016 04:43 PM
